help what motor is in a 99 suburan
Old Apr 7, 2011 | 05:47 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
it has a 5.7 liter but is it the ls block or jus a gen 1 small block
Old Apr 7, 2011 | 06:46 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: help what motor is in a 99 suburan
It is a 5.7 vortec, small block. Not a LS series motor.
Old Apr 7, 2011 | 08:14 PM
Transmission: auto
so i cant get rid of vortex intake and put a ls intake on then right jus want be a 100 percent sure thanks
Old Apr 7, 2011 | 08:36 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
If it is just the standard SBC with vortec heads, than the only real noteable difference is that the heads have a different intake bolt pattern. No an LS intake will not bolt on, its just an SBC.
Old Apr 7, 2011 | 10:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by bradley23150
... its just an SBC.
...and just happens to have the best heads the factory ever put on an SBC.
The induction system the factory put on those engines, though, was pretty lame. There are plenty of good intake manifolds available for that engine for you to put most anything else (other than LSx) on it.
2000-up Suburbans got the LSx engines, for what that's worth.
Old Apr 8, 2011 | 02:11 PM
Yeah, I know about the Vortec heads, they're what I used with my first engine build. I was pretty much just saying in regards to his specific question, that it's not the engine he was hoping for.
Old Apr 8, 2011 | 06:37 PM
84350hoz28's Avatar
Everybody here is giving you good info. I dont know if you are carbed or injected but that 1999 block does not have any provisions for a mechanical fuel pump. If you are carbed, your gonna need an electric fuel pump and a regulator.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
