305 carb to 355 carb swap/ ecm question
Car: 1983 Z28
I know that using the knock sensor is recommended. I will use the one from the 89 350 block. I have the complete TPI system.
Do I need to use the following :
1.) 350 ESC?
2.) 350 prom from the tpi ECM? If so, how will that prom work with my CCC quadrajet?
1.) 350 ESC?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 carb to 355 carb swap/ ecm question
None of the TPI parts are going to work with a computer carb setup (like the ECM, ESC, etc.). Not sure what knock sensor you will need - maybe one from a car that had a computer-controlled carbed 350 in it from factory, but I'm not sure what that would be, maybe a truck.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Swap the short block, leave absolutely everything else the same.
Car: 1983 Z28
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
To really take advantage of the larger displacement and if you put in a better cam, FAST fuel systems will burn a new chip for about $250 and rebuild that CCC Quadrajet to 350 specs for about $300.
Engine: 383 Carb
Transmission: 4L60
Or you can advance the base timing and put new rods and hangers in to get the same results for about $50 total.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
