What's the value
Old Apr 8, 2011 | 11:06 AM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
What's the value
What do you guys think the value of this description should be?
.30 over 350 making it a 355. 300 hp double camel hump heads. Has the big 2.02 & 1.6 valves. 291 casting # heads. 010 casting # 4 bolt main block brass freeze plugs. 480 lift Hyd flat tappet cam. Double roller timing chain. Hv oil pump . Manley forged flat top pistons with valve reliefs. Motor will be complete and ready to go.
Old Apr 8, 2011 | 12:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What's the value
$800.
Have the heads been drilled for accessories? If not, you'll have to drill them - they have no accessory bolt holes in the fronts for your p/s pump, alt, etc. (unless your using your 305 heads like we've been discussing - then you can sell those heads).
What's complete and ready to go mean? In my world, "ready to go" means I can start it and it runs on site - as in has an intake, carb, oil pan, water pump, starter, etc. all in place - but there's no mention of any of that - so you better get a definition of what "complete" means.
I say $800 because ... I paid $600 for my 350, and it was "complete" - carb to pan! Now, it's not pretty, it's old, it has smog heads - but it also has 10:1 dometop pistons, mild cam, and runs great. So, yeah ... I'm a tightwad! Guess maybe I've been spoiled by getting good deals in the past. Others might pay more than $800.
Good Luck!
Old Apr 8, 2011 | 01:36 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Those camel hump heads are pretty long in the tooth.
Old Apr 8, 2011 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're buying a shortblock. Those 291 heads are worthless except to a collector. You can't drill the accessory holes because there's no pad on the end of the casting. The valves and seats are soft (unless replaced/reworked for unleaded gas).
No more than $500, depending upon condition.
Old Apr 8, 2011 | 05:40 PM
hartsmike's Avatar
Axle/Gears: 273
will the 305 head push that block past pump gas?
Old Apr 8, 2011 | 09:00 PM
Car: 1992 RS
Engine: Carbed 350
OK - you got the expert answer from five7kid - he's da Man!
The 305 heads would work fine with pump gas like we discussed before - might need mid-grade or premium to avoid spark knock, but at today's gas prices, another 10-20 cents isn't even noticed anymore..
Old Apr 14, 2011 | 07:53 AM
Car: 1992 Camaro RS
Those camel hump heads should be worthless... All the backwoods guys around here still think they are the be all end all of cylinder heads. He could probably unload them pretty easily to some old school guy stuck in his ways.
Old Apr 15, 2011 | 11:47 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I was going to write something similar about these heads as maybe in the 70's they were the best, now they honestly suck compared to even late model factory offerings.
