tranny wont go into gear after swap
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
hi there. i got a tranny from a 04 gto. it came with no bell housing or torque converter. i went to the local tranny shop and bought a v8 bell housing. the guy i bought the torque converter said he believes it from a v6 but not sure. every thing bolted upmy problem is when the car is started, i put into gear but nothing. with the rear end lifted the tires will spin but as if in reverse with no gas. i believe its the torque converter connection. my ls1 cpu has a connection, where can i find it on the camaro. thanks
