High Compression
Old Apr 18, 2011 | 05:56 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
High Compression
How do you build a motor to handle 12-15 compression ratio?
Old Apr 18, 2011 | 06:03 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: High Compression
Kinda confused on what you want to know. 12: CR is a lot. 15:1 is a ton. Even 12:1 would have to run on race gas. Are you asking how you get that high of a compression ratio? Why do you want a compression ratio that high? You really wouldnt be able to drive it on the street at all.
Old Apr 18, 2011 | 06:06 PM
Axle/Gears: 3.08
I have a motor with 9.5:1 ratio and like to run a supercharger about 6-8 psi. Holley compression chart says it would be 13:1.
Old Apr 18, 2011 | 06:12 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Not sure how you were looking at a Holley supercharger compression chart without access to the rest of this info.......it lays it out in detail.
http://www.holley.com/data/TechServi...ech%20Info.pdf
Old Apr 18, 2011 | 06:56 PM
Axle/Gears: 3.08
what would be a safe psi to run? Im new to the supercharger world?
Old Apr 18, 2011 | 07:19 PM
flrtin1's Avatar
Engine: S/B
Your questions are not making a lot of sense without more background of what you are wanting to do or know..........try doing a bunch of reading/research with the link I provided and info found at BDS and Dyers sites, they pretty much cover all the basics and will give you a better understanding of how it all works on a roots blown build.
Old Apr 18, 2011 | 07:41 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Super chargers & turbos use 9, 9.5:1 at the most, & forged pistons, (forged rotating assembly for all out racing//hi rpm use.)
7.5:1 is a starting point. Great heads & right cam would be beneficial.
flirtn1 makes perfect sense.
I'm thinking you are asking what your total compression would be with a blower/supercharger.
In short, the engine must be assembled for blower/super charger if you want it to last.
Old Apr 18, 2011 | 08:09 PM
bigjoebowski22's Avatar
If you want to run over 12:1 compression with forced induction, you're gonna need to go with E85 at the bare minimum. You may even be pushing it with E85.
E85 behaves similar (note the wordage, similar) to C16 race gas. E85 is about the equivalent to 105 Octane, and the cooling effect it has on the cylinder helps it out a bit more. The only catch is, you're going to need about 50 percent more fuel at WOT, and less at part throttle and cruise.
Also, 12:1 is only your static compression ratio. You'll lose some of that cylinder pressure with a big cam, which is referred to as a dynamic compression ratio, and the more important of the two. Most engines running higher static ratio compression do so because they have a lot of valve overlap, and need to compensate for the air that's pushed out of the exhaust valve at the beginning of the compression stroke. Once you learn a little more about engines, you'll know that forced induction engines don't like a lot of valve overlap.
Old Apr 18, 2011 | 08:37 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
What the???
i thought you want low compression with forced induction... doesnt higher compression create higher vacuum pressure??? boost and vacuum press. are on the oposite sides of the spectrum.
12 to 15 compression... thats insane especially with iron heads. ive heard of 10.5 to 11.5 on an engine with aluminum heads.
everyone i know in the real world that runs a forced induction v8 stays around 8.
Old Apr 18, 2011 | 08:42 PM
Originally Posted by TNT_Z28
What the???
everyone i know in the real would that runs a force induction v8 stays around 8.
Generally, yes. Most people run less than 9:1 compression with forced induction. Higher compression does not create more vacuum. Valve overlap, throttle angle, and engine RPM do.
Old Apr 18, 2011 | 08:50 PM
TNT_Z28's Avatar
good point... compression has to do with how much the combustable gases are compressed. hence the term compression ratio.
why then, does everyone stick to a low c/r for forced induction?
just interested...
Old Apr 18, 2011 | 09:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I have a 12.1: 1 383 alum heads
The 236 / 242 cam brings the DCR back to the approved range. (8.6 )
Old Apr 18, 2011 | 09:08 PM
just interested...
Usually to run more boost. More air = more fuel = more bang. Higher compression doesn't add more fuel and air into the engine, it only compresses the fuel/air mix more, which creates more bang, but not as much bang as more fuel and air.
FormulasOnly
Jul 23, 2018 08:47 AM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
