400 TPI
Old Apr 28, 2011 | 03:48 PM
bigrobwills's Avatar
Car: 87 camaro z28
Axle/Gears: 10 bolt 3.73
400 TPI
Has anyone done this and do you have any pics
Old Apr 28, 2011 | 03:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure why pictures would make any difference. It would look like a 305 TPI, or 350 TPI, or a 383 TPI, or...
Here's what you can do: Go back to the Engine Swap forum page. Near the top on the blue line is "Search This Forum". Click on that, then "Advanced search" at that bottom of that subwindow. From there, on the left enter "400 TPI" in the search text box, then below that in the pull-down window select "thread topics only". Then click on "Search". About a page' worth of hits will show up. Read to your heart's content.
Old Apr 29, 2011 | 08:59 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 400 TPI
My neighbor has a 406, TPI, technically has the Super Ram, but... it looks exactly like a 305, with a super ram...
John
Old Apr 29, 2011 | 09:05 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: 400 TPI
the 400 with a TPI would be an awesome torque monster. I have always wanted to build one of these but never got around to it. It will physically bolt together but you will definately have to have a custom chip burned. This motor won't rev very high at all but it will surprise you where you need it.
Old May 1, 2011 | 07:23 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: 400 TPI
Check out this article where they compared different TPI intakes on a 383 with TFS heads and aggressive cam. Stock intake only really feeds enough air on a 305. You can see power gains from article with intakes that flow more than stock.
http://xtremecarzone.com.au/index.php?showtopic=386
I'm going to build a 420 sbc with a FIRST TPI intake.
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
