Need couple ?s awnsered if possible
I have a 92 firebird swapping 305 to a 350 carbed, can i bolt the thottle body bracket from the 305 to the 350 and the distributer looks like it had wires coming out the sid but doubt it its a 78block got a new dist cap rotor and coil and hei plug will the tach wire work and what color is it off the motor, any links u can give me would be great.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need couple ?s awnsered if possible
There's a tech article about carb swaps - that explains the wiring from the cc distributor to a vac-adv distributor as well as the other issues that need addressed https://www.thirdgen.org/carbswap
can u tell me the color the tach wire is forgot to label it? Also missing the bottom 3 wires from the dist that plg in the cap are they essential or can it run with just the batt and tach connector
RedLeader289
May 28, 2019 01:47 PM
Linson
Oct 1, 2015 09:50 PM
