i need wiring harness help bad
Old May 18, 2011 | 10:47 AM
voljim's Avatar
i have an 82 camaro with a 305 tpi in it i thought came out of an 87 but, it has an hei distributor in back of motor not on the nose i got a wiring harness but it is set up for a nose mounted. i need to know can anyone tell me what year harness i need to get
Old May 18, 2011 | 02:50 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: i need wiring harness help bad
what do you mean nose mounted? TPI motors all had HEI's mounted in the back of the engine. Some had small cap and some had large cap. If you have a large cap in your motor and your harness is for the small cap. You could swap the distributor and external coil on instead of changing the harness.
Old May 18, 2011 | 03:42 PM
voljim's Avatar
well i was told it might have been something like that but the alternator wires don't plug up and the distributor wires i was told the pick up wiring will not match up
Old May 24, 2011 | 10:51 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
tpi wasn't avail 82' is this an incomplete swap?what did the 82 have originally,'it will need more than a harness to run TPI
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
