Help with engine removal, Almost there...
Old May 23, 2011 | 09:28 PM
SSZ2891's Avatar
got a 92 rs with the 305 auto tranny. im curious whats the easiest way to remove. do i have to remove hood. and should i remove it with the tranny attched or no?
Old May 24, 2011 | 12:38 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: Help with engine removal, Almost there...
Yes, remove the hood. It will be quicker to pull it with the tranny attached. I would recomend removing the Radiator as well so it doesn't get damaged.
Old May 24, 2011 | 04:10 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
some pics https://www.thirdgen.org/forums/engi...wap-305-a.html
Old May 24, 2011 | 09:14 AM
SSZ2891's Avatar
not too bad.. i already got the radiator out. hood shouldnt take long. as far as removing the tranny and engine where do i disconnect the tranny? this will be my first time removing an engine
Old May 24, 2011 | 02:39 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
unbolt the drive shaft yoke and then you can pull off the drive shaft. Then unbolt the torque arm from the tranny mount and I think you have to take the transmission crossmember off.
Old May 26, 2011 | 10:15 AM
SSZ2891's Avatar
i just bought the hoist and stand. should i buy a lift plate... heres one from autozone
http://www.autozone.com/autozone/acc...Plate/_/N-25p1
Old May 26, 2011 | 10:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you don't have a carb manifold the plate isn't going to be very useful.
Old May 26, 2011 | 10:27 AM
SSZ2891's Avatar
how would i get it out then. just with a chain? couldnt that slip though?
Old May 26, 2011 | 10:35 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
just unbolt the bolts from the intake manifold, also, when taking down the drive shaft, what side do you disconect first, i took out my engine but i left the tranny, big mistake, its a stick so the clutch gets in the way, so ill drop the tranny, so. please more detail in removing the tranny
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
