what are these bolts on my block??
Old May 23, 2011 | 11:30 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
I have a 1979 4 bolt main 350 engine in my camaro, its had been rebuilt but i have 4 bolts on my engine that have screws half way out...i need to know what they are.... ( not the motor mount plate bolts)
i put a picture i found off google and i circled the bolts..but mine just has a bolt sticking half way out of each. the top ones leak. --- my questions are......
1.) do i plug them? and if so, could a bolt be to long? and do i need thread sealer?
2.) do theses bolts have to do with accesories like a gauge for oil temp? if so i have a oil temp gage, but were do i put the sensor? and like stated before could the sensor be two long???????? let me know please, i will be puting the engine back togeather tomorrow.
THANKS!
-Matt
Old May 24, 2011 | 04:09 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Re: what are these bolts on my block??
the bottom one might be the knock sensor, your gonna need that. I'm not sure about the top one, sorry
Old May 24, 2011 | 04:13 AM
defaria27's Avatar
A knock sensor in a 1979 motor?
Old May 24, 2011 | 04:44 AM
Twin_Turbo's Avatar
the bottom one is a coolant drain hole, not a bolt hole. it's NPT threaded, not UNC. The factory used this for the knock sensor w/ EFI equipped cars but the hole was always there on earlier castings. Normally they have a plug there which can be removed to drain all coolant. The petcock there is something the rebuilder does.
the other hole is used for a support strap for the starter
Old May 24, 2011 | 04:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Correct, except the later computer carb models, and the L69 carb engines, also had the knock sensor (not limited to EFI).
Correct. If it is leaking, I'd guess someone installed too long of a bolt and punched a hole into the coolant jacket. Not a big deal if you can get it to seal. I had heads that leaked from the exhaust bolt holes (too long of bolts used, punched a hole into the coolant passage), I just put sealant around the threads to keep it from leaking. As long as the outer block wall isn't cracked, you should be able to do the same with the top bolt hole in your block.
BTW, that accounts for 3 holes. You said you have 4 you are wondering about - what's the 4th one?
Old May 24, 2011 | 04:21 PM
Twin_Turbo's Avatar
If it's on the other side, it's a thread used for a mechanical clutch pivot stud.
Forgot about the CCC arbs, yes, they too have an EST/ESC system.
Old May 24, 2011 | 04:35 PM
five7kid's Avatar
You're probably right, but it isn't in the same location as the picture posted.
Old May 24, 2011 | 05:02 PM
Twin_Turbo's Avatar
No it's closer to the filter pad.
evilstuie
Jan 9, 2020 08:29 PM
C409
Sep 23, 2015 04:30 PM
Gambit TA
Sep 1, 2015 07:27 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
