2.8 v6 to 5.0 tpi no spark or fuel
Old Jun 8, 2011 | 02:15 AM
adie's Avatar
Car: Pontiac Firebird
Engine: 2.8 v6
Transmission: auto
Just swapped in a 5.0tpi into my 2.8inj firebird,both 1989 (i think),swapped the engine loom and the computer,engine turns over,fuel pump primes but no spark or fuel?Not 100% sure they are the same year maybe 1989 or 1988.
Old Jun 8, 2011 | 03:14 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: 2.8 v6 to 5.0 tpi no spark or fuel
Check for loose/crimpped wires at the dizzy make sure it hooked up in right spot check fuel pump fuse its located behind headlight its a 2 wire black single fuse holder with red/orange wires if i rember correctly could also be an issue with your vats (security)
Old Jun 8, 2011 | 12:51 PM
adie's Avatar
Engine: 2.8 v6
Transmission: auto
ok thanks I will check them,the fuel pump does run though,just not getting any fuel in the cylinder.Could there be any wiring problems between the new engine loom and the car loom?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
89bird2.8
Sep 22, 2015 05:28 PM
Springster
Sep 13, 2015 01:38 PM
