305 TBI to a 350TBI Engine swap
Old Jun 21, 2011 | 07:24 AM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
I am nearing the final part of my new engine build and am wondering what else I have to look forward to that will create problems for me. Let me fill you in as to what we did.
We took a 350 TBI we found in a junk yard that was burried on a bus with many other engines. Stripped it down to nothing and redid everything. We went .030 over on the heads, roller rockers and lifters, radical cam, timing gear, 2500 rpm stall converter, tranny remains 700R4. The rear has a BWposi 3:29, traction control bars and disc brakes. Can I run the car with the original 305 computer? Do I have to use the TBI that came with the 350 or can I use the TBI that came off the 305? Or can I use the 305 throttle body and just swap out the injectors from the 350? I am trying to get away with using the existing wire harness and computer for the 305 and just have a chip burned. The heads are almost identical from either engine.
Old Jun 21, 2011 | 02:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by mac86
We went .030 over on the heads...
Do you mean 0.030"-over on the cylinders?
3.27:1, perhaps?
The TBI forum has a bunch of info on going from 305 to 350.
305 heads have 1.84" intake valves and 58cc chambers. The 350 heads have 1.94" intake valves and 64cc chambers. Both are the hated "swirl port" heads.
Old Jun 21, 2011 | 03:01 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: 305 TBI to a 350TBI Engine swap
Congrats on the swap! i did my swap from my old 305 TBI to a 350 buick roadmaster type H motor. And you can keep the same computer,but you need a different chip. I found that old a while ago. Go to TBI Chips.com and let him know all of your options. HEs a great day and ships fast. And if you need something changed on the chip, you can send it back and he will do it for free. You can use the same Throttle body, you just need to swap the injectors.
Old Jun 21, 2011 | 07:16 PM
mac86's Avatar
Engine: Carbed 355
yea, you are right 3:27. I must have typed it wrong. Its correct in my profile though. Sorry. And yes it 30 over. on the cylinders. This is my first build and man the terminology is nuts. I should have it down by now but still being corrected where ever I go. Just yesterday I ordered a temperature switch and needed a sending unit. Wrong part again. Soon I will listen to my 15 year old son and do the right thing. He is the Brains of the operation. I am just the money man$$$$.
Old Jun 21, 2011 | 07:18 PM
mac86's Avatar
Engine: Carbed 355
What is so bad with the swirl port heads? Can you recommend another TBI Intake that can be used?
Old Jun 21, 2011 | 09:56 PM
Guest
Guest
Posts: n/a
Swirl ports don't flow. Period. Forget making more than maybe 250 HP with them, unless you get nitrous or boost.
Edelbrock makes a dedicated TBI intake manifold, and Holley makes a version of their Pro-Jection II intake manifold for early heads, and another for later heads.
camaro11j
Sep 19, 2018 08:49 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
