Doing the usual 350 swap. What motors have roller cams?
Old Jul 2, 2011 | 12:03 AM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Hey guys, my car has a 305 TBI in it right now and it is giving me that valve seal smoke. Only it is not at startup anymore it's whenever I hit the gas. So I was going to look into a 350 TBI setup. I was wondering which 350 motors came with the roller cam and lifters like my 305 has. I like that setup and would like to keep it. The only engines I know that came with it are the one's in the fbodies. Are there any others? Thanks in advance for any info you can give.
Old Jul 2, 2011 | 08:31 AM
Guest
Guest
Posts: n/a
Re: Doing the usual 350 swap. What motors have roller cams?
For blocks, any '87-up 350 block will do.
For lifters, any '87-up 4.3, any '87-up car 305, including Caprice, any '87-up 'vette, any '87-up F-car, any '96-up pickup. You can also use LTx and / or LSx lifters. They were carried over unchanged.
But since you already have a set in your 305, you can just transfer those over.
Old Jul 2, 2011 | 09:42 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
just keep in mind that if you change cams, you want new lifters. never wanna use used lifters with a new cam...
Old Jul 2, 2011 | 09:56 AM
rffy's Avatar
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
I was always told that you could re-use roller lifters. Are you sure you can't reuse them?
Old Jul 2, 2011 | 10:02 AM
travis401's Avatar
Car: 91 Camaro RS
rollers yea, i still had flat tappet stuck in my head...its still early
Old Jul 2, 2011 | 02:06 PM
macmatt's Avatar
Engine: 305 TBI
Thanks guys for the help. I was under the impression though that the truck motors that set of years had standard flat tappet cams and lifters. At least the ones I've found in the local junk yards have. Perhaps I am reading the VIN's wrong. If memory serves I can't put a roller cam into a non roller cam block can I?
Old Jul 2, 2011 | 02:24 PM
travis401's Avatar
Car: 91 Camaro RS
you can put a roller in a non roller block, but it requires retro fit roller lifters....which are WAY expensive.
Old Jul 2, 2011 | 03:18 PM
Guest
Guest
Posts: n/a
All of the '87-up blocks will accept the stock roller lifters from your 305.
None of the '87-'95 SBC trucks came with roller lifters.
It doesn't matter.
You already have a set of roller lifters, which all of the '87-up blocks are machined for.
Buy the non-roller 350 from any '87-up pickup, then remove and discard the stock cam and lifters.
Next, install the hydraulic roller cam of your choice, and install your 305 hydraulic roller lifters.
At that point, you have a roller 350.
Old Jul 2, 2011 | 03:25 PM
travis401's Avatar
Car: 91 Camaro RS
are the 305 lifters the ones with the bar connecting the pair?
Old Jul 2, 2011 | 05:49 PM
Guest
Guest
Posts: n/a
No, those are retros. Stock lifters use the "dogbones"
Old Jul 2, 2011 | 11:24 PM
macmatt's Avatar
Engine: 305 TBI
Ok cool. Just to be sure though...My block has the 'dogbones' that connect the lifters but it also has a bolt in metal retaining plate. The truck blocks, to my knowledge, are not cast with the bolt holes for this retaining plate. But I could be wrong.
Attached Thumbnails Doing the usual 350 swap.  What motors have roller cams?-000_0115.jpg
Old Jul 3, 2011 | 07:40 AM
Guest
Guest
Posts: n/a
How did you become such a doubting Thomas?
Look, you have to pull the intake manifold anyway, to be sure there are no cracks in the lifter valley. At the same time, you'll see if the provisions are there.
Those blocks came from at least 2 different foundries, one of which was in Canada. I've seen one, but couldn't disassemble it.
Back to the American blocks: Even the '86 blocks had the spider bosses. They weren't drilled and tapped, but they were there.
I have seen where a Rebuilder was using older 350s for LO5 replacements, and you may find that. It makes some sense, since LO5s didn't need rollers.
How was the foundry supposed to know which 4-bolt blocks were destined for 'vettes, and which for 1-tons? How were they supposed to know which 2-bolt blocks were going in Camaros, and which for 1/2-tons?
You now have all the correct info you need, please switch from typing to wrenching.
Old Jul 3, 2011 | 08:31 AM
macmatt's Avatar
Engine: 305 TBI
OK cool. I'll keep my eyes open for the blocks specified. Thanks for all the help.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
