swapping 2.8 mpfi to 305 tpi. quick question
Old Jul 4, 2011 | 01:42 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Hey guys. Just secured a 91 305 tpi engine, trans and all parts for swap. I need to know if my exsisting fuel pump will run the 305. My 2.8 was muliti port injected. I do have the correct fuel lines for the swap.
Also, I'm in need of the exhaust y-pipe. The 305 does have headers on it. Need a decent used one for now until I secure more funds for a stainless exhaust system.
Thanks guys!!!!!
Old Jul 4, 2011 | 01:45 PM
Guest
Guest
Posts: n/a
Re: swapping 2.8 mpfi to 305 tpi. quick question
We have a thing called "search" but even without that, had you just scrolled down this page, you would have found this thread: https://www.thirdgen.org/forums/engi...-question.html , which has your answers in it.
Old Jul 4, 2011 | 01:50 PM
Well, I only have a smart phone which won't allow me to use the search feature. Sorry. But thanks for the help anyway ...
Old Jul 4, 2011 | 01:51 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
if its for sure a tpi engine (not tbi) that is getting swapped, then yes your fuel pump used with the 2.8 fi will work.
Old Jul 4, 2011 | 01:56 PM
It is for sure a speed density controlled tuned port injected 305. Thanks!
BlueIroc-Z
Jun 9, 2019 03:22 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
st.evel07
Aug 13, 2015 06:15 PM
jahblah
Aug 12, 2015 05:54 PM
