Fuel Pump Question
Old Jul 1, 2011 | 03:33 PM
ChrisLeBlanc's Avatar
Car: 1986 Firebird
Engine: Swapped 1986 Trans Am 5.0L TPI
Transmission: Gearstar Built Level 2 700r4
Axle/Gears: 3.42 Peg leg / Soon 2.77 BW
Fuel Pump Question
A quick question relating to fuel pumps.
I recently swapped a TPI 5.0 V8 into a 2.8 MPFI.
Now it will crank but not fire, but will run on starting fluid.
The spark plugs are dry in the motor.
Could the V6 fuel pump not be pressurizing the injectors and not opening them?
Thanks.
Old Jul 1, 2011 | 03:59 PM
Guest
Guest
Posts: n/a
Re: Fuel Pump Question
Your problem isn't much different than my current one: How to get the 2.8 pump to do it's job?
Did the TPI V8 have VATS? If so, that could be your problem.
If not, did you temporarily bypass the oil pressure switch? If not, that'll keep the pump from pumping. After the V8 has run once, you can remove your bypass, and reconnect the wires to the switch, then never need to bypass again.
That's as far as I've gotten. So if that doesn't solve it for you, then I hope someone else will help us find the correct solution.
Old Jul 1, 2011 | 04:17 PM
Car: 1986 Firebird
The fuel pump primes when the key is in the on position. And while it cranks it builds oil pressure. The car was not equipped with vats.
Old Jul 1, 2011 | 04:45 PM
luvmy64's Avatar
I dont think the 2.8 pump is putting out enough pressure. Check it with a gauge.
Old Jul 1, 2011 | 06:50 PM
Car: 1986 Firebird
I have the car the 305 is from so I'll rig the other gas tank and fuel lines up to see if that'll fire her up.
Thanks.
Old Jul 1, 2011 | 07:55 PM
Guest
Guest
Posts: n/a
The '85-'89 2.8 pumps make enough pressure and volume to idle and fast-idle the TPI 305. The 2.8 pump might not push the volume of gas required for 200 HP, but until it runs out of volume, it'll make enough pressure.
Old Jul 1, 2011 | 11:09 PM
Car: 1986 Firebird
Problem solved. Thick headed me got the firing order backwards on the distributor. Lmao. Thanks for the advice though!
Old Jul 3, 2011 | 03:30 AM
luvmy64's Avatar
WHAT?......EVERYBODY knows 18436572!
JK, glad you got it going......
Old Jul 3, 2011 | 07:42 AM
Guest
Guest
Posts: n/a
No, that's cast right into the intake manifold, so he must've went counter-clockwise.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
