Typical Engine Swap Cost
Old Jul 7, 2011 | 08:08 PM
jaweiss's Avatar
Car: '91 Camaro RS
Engine: 383 Stoker
Transmission: Pro-Built 700R4
Axle/Gears: 3.42 Detroit Locker Posi
What should it cost to do a engine swap? My car currently has a 350 and will be replaced with a 383. Nothing special should be required in terms of swapping. Just unbolt, disconnect and then rebolt, connect. Every shop around here I've talked too wants between $1200-$1400. That seems like $100/hr in terms of time and dollars. Does this sound right? I've read some posts that say a typical straight forward swap with no shop mods should cost around $600-$700.
Old Jul 7, 2011 | 08:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Typical Engine Swap Cost
In my book, 1 friend, and ... 1 day disconnecting everything, one afternoon swapping motors with a rental hoist from any tool rental company, one (or more) days reconnecting everything, retuning, etc. Total cost = $35 rental fee + $20 in beer!
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
where are you located?
Are you carbed?
If youre just doing a straight forward engine swap, its not hard.
Just take some pictures in case you cant remember what goes where.
I'd do it for 500 bucks if you were local, and i work on dirt. lol
9 chances out of 10, it'll be easier to unbolt exhaust, motor mounts, and all electrical, dizzy, trans cross member, driveshaft and torque arm, trans lines, radiator, fan, and ****** the combo out the car.. re assemble trans to 383 and go back in.
relatively simple, they're peeing on your leg and tellin you its raining if it "costs" that much.
at 100 an hour, i could probably do for 5-600 bucks. a good shop should be about the same or less.
Good Luck
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
$100/hr is quite typical. Thats what the shop i work at charges and we are on the cheaper end. Also an estimated swap according to MITCHELL is 12hrs.
Old Jul 7, 2011 | 09:01 PM
jaweiss's Avatar
Car: '91 Camaro RS
Engine: 383 Stoker
I have TBI and I'm located in Illinois. I'd pay $500-$600 but not the $1200-$1400 these shops are asking. Hell to have this 383 built is only costing me $2400. The damn install is as much as the motor almost. Anyone close want to do it? I'll pay for beer and gas!!!
Old Jul 7, 2011 | 10:12 PM
Engine: 355 chev
damn, i just had a good friend of mine go visit their family in Il. I'm 900 miles out from IL.
Shoulda built the 383 yourself!
Old Jul 7, 2011 | 10:23 PM
jaweiss's Avatar
Car: '91 Camaro RS
Engine: 383 Stoker
I would of if I knew anything about building a motor ;-)
Old Jul 7, 2011 | 10:46 PM
Engine: 355 chev
its all simple. most of it is. well , some of it. nothing about assembling it is simple.
hahahah.
nah, in seriousness, it is relatively simple. just being clean, and torquing stuff right, keep your gasket surfaces clean, and its a breeze.
The same thing with transmissions. Everyone talks about how much of a pain they are, stuff, and ive been into two 4l60e's and a few powerglide race trannys, and i turned 19 last thursday. Just pay attention, and remember where stuff goes. You can install yourself.
Old Jul 9, 2011 | 07:00 AM
torque_is_good's Avatar
hahahah.
not picking on you but, when I was 19, I'd say the same thing as you. As you gain knowledge and experience, you will learn to expect the unexpected and be proactive. Builders call that "measure twice, cut once".
To the OP: that is a fair price you are being quoted by a professional shop. If you want a cut rate price then you damn well better be willing to expect cut rate craftsmanship. You might get lucky but you need to be willing to make a tradeoff if you look for it on the cheap.
You can buy a lot of tools for $1200
To listen to posters on these forums say that "I'd do it for $500 or $400 etc etc" they of course aren't paying
rent or mortgage
liability insurance
workmans comp
unemployement insurance
7% of social security for the employees
uniforms
electrical
water
heat
shop equipment
maintenace of shop equipment
payroll
technology- copiers, computers, phones, on line jobber manuals and flat rates, Internet
supplies
federal taxes
state taxes
salaries
advertising
disposal of hazardous waste
placing a warranty on the work because they have the knowledge, tools and experience to back it up.
It kind of makes you feel silly to think that you complained about the labor rate. if you don't want to pay it, then do it yourself.
Old Jul 9, 2011 | 08:45 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
rent or mortgage
liability insurance
workmans comp
uniforms
electrical
water
heat
shop equipment
payroll
supplies
federal taxes
state taxes
salaries
advertising
exactly what he said (Y)
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
