Serpentine conversion
Car: 1983 Z28
Converted over to this and have a couple of questions. Since the alternator is on the opposite side, I have to make some adjustments.
I had to buy a new pigtail for the newer alternator, but it has 3 wires from it, one larger one. The wires from my stock configuration only have two. What do I need to connect this properly? I have a single wire that originally went to the back of the alternator bracket, does this need to be spliced into that 3rd larger wire on the newer alt?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Serpentine conversion
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You do know the water pump has to be replaced as well, right? And maybe the p/s pump also?
Car: 1983 Z28
Yes. I replaced everything with new.
I do have another question. The serpentine ac compressor has 2 prongs on the front, and a round 2 prong in the back. Are both supposed to be used? My factory pigtail only fits the front.
Oops. Double post.
JamesC
JamesC
https://www.thirdgen.org/forums/susp...-3-pt-stb.html
JamesC
Car: 1983 Z28
Only the front for mine. Check post #18 below, pic #3 for a visual:
JamesC
JamesC
Ok, thanks. I already bought a round pigtail and connected it to the rear. Why are there 2 ports, anyway? Oh well, I'll reconnect the old pigtail.
