'85 2.8L V6 swap to a 305 or 350 V8 HELP!
Old Jul 10, 2011 | 10:34 PM
cannon12's Avatar
Car: 1985 Camaro & 1994 Camaro
Engine: 85 - 2.8L to 5.7L, 94 - 3.4L
Transmission: T5 5 speed
My 2.8L V6 engine finally gave up on me after 350,000 mile on it. I thought she'd go forever! My question is, if I upgrade to a 305 or 350 V8 engine, will the 5-speed transmission that is in the car now work with the upgraded engine, or is there an adapter that can be purchased to make it work for me? Any help would be greatly appreciated!
Old Jul 11, 2011 | 03:43 PM
GSRacing's Avatar
Re: '85 2.8L V6 swap to a 305 or 350 V8 HELP!
imo i would just put a th350 in it with a 1500 or 2000 stall converter and a manual valve body itll be about the same honestly i hate shifting gears now
Old Jul 11, 2011 | 07:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Bellhousings on V6 cars are different bolt patterns than V8 cars (60 degree motors vs. 90 degree motors).
Old Jul 11, 2011 | 10:21 PM
cannon12's Avatar
Some have said there might be an adapter or something to make it work.
Old Jul 12, 2011 | 12:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can get a V8 bellhousing and mount it up. However, the clutch can be an issue, because the input shaft of the V6 tranny is smaller than the V8 version, so you can't use a V8 clutch disk. I've heard a 4.3 S10 disk has the proper spline size and is almost as large as a V8 disk, so you can use it with a V8 flywheel and pressure plate.
But, the V6 T5 is very weak (see "input shaft" above), so you won't be able to drive it like it's got a V8.
Your best bet, if you want to keep a manual transmission, is to get a V8 version.
I would not put a TH350 in a street car.
88rscamar0
Sep 23, 2015 09:08 PM
gwade12
Aug 8, 2015 08:17 AM
ChrisFirebird
May 3, 2001 03:29 PM
CamaroVroom
Apr 12, 2001 01:51 PM
82camarov6
Nov 8, 2000 06:29 PM
