Opinions needed on engine overhaul
Old Jul 23, 2011 | 09:28 PM
tlandoe's Avatar
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
Hey guys, I'm looking for some opinions on an engine overhaul. My 83 Crossfire 305 has 90,000 miles on it and runs like a top. It does leak some oil at the front seal behind the harmonic balancer and burns oil at startup since the valve seals are worn.
What I'm wondering is if the engine's totally fine, could I get away with pulling the thing apart and replacing all the seals and gaskets, ring etc. Without doing any machine work? Nothing's been seized or starved of oil in the engine, so I don't think replacing any bearings would be necessary.
Do you guys think this is a good idea? I've only rebuilt two engines and those were full rebuilds. I'd love the save the unneeded trouble.
Old Jul 23, 2011 | 11:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Opinions needed on engine overhaul
I did a rebuild like that back in the early 90's. I think it was around $500 for bearings, gaskets, seals and rings. Nothing special. Just stock replacement parts, not performance parts. Cost of OEM type parts are probably a lot more now.
Engine ran great after the refresh.
Old Jul 24, 2011 | 09:38 AM
chesterfield's Avatar
Car: Pontiac
Originally Posted by tlandoe
Hey guys, I'm looking for some opinions on an engine overhaul. My 83 Crossfire 305 has 90,000 miles on it and runs like a top....
Do you guys think this is a good idea?....
No, if it ain't broke don't fix it. If it doesn't need new rings, then new rings won't improve anything. If it runs like a top, then tearing it down is just inviting problems. Fix the timing cover leak and the valve seals and drive it another 100k
or more. What's that? Another ten years of driving? Just my humble opinion. Or maybe I'm just lazy.
Edit: On second thought, if you're going in that far, you may as well replace the timing gears and chain. And water pump.
Old Jul 24, 2011 | 05:02 PM
tlandoe's Avatar
Axle/Gears: 2.93
I think maybe you're right, I should just go and do the seals and the chain/water pump. I'd really love to make it like new, I'm getting all new paint and interior, the only other thing that would make this a full restoration is an engine overhaul
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
