Interesting swap concidered
Old Aug 10, 2011 | 01:01 AM
davesengineshop's Avatar
Car: 1983 Z-28
Engine: 454
Transmission: TH700R4
Axle/Gears: 7.5" with 3.23 gears
Any one ever heard of , seen or put a 302 ford and ford transmission in a 3rd gen
Old Aug 10, 2011 | 01:33 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Interesting swap concidered
Have fun cracking your block in half!
Old Aug 10, 2011 | 03:01 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Why would you want to make it slower? Just because you have it, doesn't mean you should use it....
Old Aug 10, 2011 | 08:21 AM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Good luck with that
Old Aug 10, 2011 | 01:13 PM
torque_is_good's Avatar
contact vonkaiser from this thread. he must be done with the SBF swap by now
https://www.thirdgen.org/forums/engi...02-my-3rd.html
Old Aug 10, 2011 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not necessarily. In fact, not likely.
Old Aug 10, 2011 | 03:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i know it may seem interesting, but there is a reason why the ford guys are doing LSx swaps into their cars more than you see the GM guys putting in ford parts. the value isn't there when you take in the amount of time and fabbing required to do something like that. there's something to be said about being "different", but don't waste a ton of money to say so.
on that note, there are *tons* of options out there for engines that will nearly drop into a 3rd gen, its one of the reason why they're so popular. wanna keep it simple? go sbc. want a potent setup with great drivability? go LSx. wanna be a little different? boost a gm v6.
there are enough headaches to be had when doing any motor swap, don't over complicate things just for the sake of being different
Old Aug 10, 2011 | 03:10 PM
Guest
Guest
Posts: n/a
Why? For the novelty? That gets old. Already have the engine? Sell or trade it. More familiar with it? Doing a TPI SBC works on the same principles. The EEC-IV control? This isn't 1987, it's 2011. For the glory? Everyone will say: "Props", but neither the Ford guys nor the GM guys will respect you more for having done it, if you can.
Old Aug 10, 2011 | 08:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've seen chev engines in fords and ford engines in chevs. I've seen dodge engines in chevs. Some people do it because they like a body style but prefer a different engine. There's lot of ford and dodge body styles I like but don't care for the engines.
With enough fabrication skills, time and money, any swap is possible. Is it worth it? Probably not. The old 302 ford engine was always a popular swap into older vehicles because it was a very narrow block which could be dropped between the frame rails of just about anything. It might not have been the best option but it was an easier swap.
Performance wise? Lots of 5.0 ford aftermarket parts are available but as mentioned above, ford owners are dropping in LS engines into their fords for a reason. If you look at the head bolt pattern on a 5.0L ford compared to a SBC, you can see why the fords are always blowing head gaskets.
Old Aug 10, 2011 | 09:57 PM
Guest
Guest
Posts: n/a
Originally Posted by AlkyIROC
Ford owners are dropping in LS engines into their fords for a reason. If you look at the head bolt pattern on a 5.0L ford compared to a SBC, you can see why the fords are always blowing head gaskets.
That doesn't hold up, when the LSx, like the SBF, has 4 bolts around each cylinder, and HotRod just twin-T76'ed a 4.8L to 1200 HP with no O-rings.
Old Aug 10, 2011 | 10:26 PM
1gary's Avatar
Well I don't agree with this swap,but here are the sizes you would need to know:
http://www.carnut.com/specs/fengdim.html
Old Aug 10, 2011 | 10:39 PM
Guest
Guest
Posts: n/a
To follow that fine example, I believe I'd use the late-'80s Mustang oilpan, and a tubular crossmember. The exhaust situation seems rather obvious, as does cooling and fuel and driveshaft. Transmission looks easy with a Jegs torque arm. B7M console Megashifter fits our cars, but the guts are easily configured for AOD, if you don't go T5 or T56. If you do, then McLeod can take care of the HTOB for a Ford version, or there are adapter plates to use a GM version, then keep the torque arm. Much cheaper. Or TCI makes a kit to use a GM automatic behind a SBF.
Orr89RocZ
Apr 25, 2016 08:28 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
overdriv
Aug 20, 2015 03:52 PM
