motor swap i need help
Subscribe
Aug 28, 2011 | 08:19 PM
i have a 89 350 going in a 88 firebird the block # are 10054727 the heads are 14102183 are these any good i would like to get the most hp out of this i would like to know what carb, intake,cam,headers and y pipe and maybe a stall speed to use it been 20 years cince i messed with a car it going to be for my son thank for any help you can give
Reply 0
Aug 29, 2011 | 04:11 PM
Welcome aboard thirdgen.org.
The block is a decent one. 1-piece rear main seal, usually good casting and machining quality. Do you know if it has roller lifters?
Are you sure about the head casting #? 14102193 is listed, but not 14102183. The 14102193 are the common TBI swirl port heads, which are fine for "stock" builds, yielding decent economy and power, but are not good enough to consider for any type of a performance build. Since you're talking about a carb build (which isn't street legal in the U.S. for '88 model year cars), I have yet to be shown a deal to beat this one for a mild street/performance build http://sdparts.com/details/scoggin-d...ter/sd8060raag . If you're talking about a track-only race car, then the recommendation would be different.
Since you asked about a Y-pipe, I'll assume this is a street car. The best off-the-shelf headers and Y-pipe out there is the Hooker 2055HKR. Shortie headers, 1-5/8" primary tubes, 3" Y-pipe. Works fine for 400 HP builds. They may seem pricey, but they will maintain good ground clearance, and anything that performs as well will either kill ground clearance, and/or cost you more by the time you get it all hooked up.
Cam - lots of choices there. People seem to make good power with the Comp Cams XFI series cams. Choose one in the 280 advertised duration range, below the .575" lift capability of the head kit linked above, and you'll love the throttle response and power.
Reply 0
Subscribe
