tuned port swap
Old Sep 6, 2011 | 08:36 AM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
tuned port swap
im currently thinking of ideas for my firebird. im doing an engine swap and havent decided of im doing a tuned port engine or a carbed engine. i like the way the tuned port looks and the fuel economy of the fuel injection. i want to do a 350 with a mild cam double hump heads and a rebuilt bottom end.
my question is sort of engine swap/electronics. im putting a summit racing wiring harness in the car which will replace the stock wiring and bulk head connector on the driver side. ill be pulling the tuned port set with wiring and ecm from an fbody so my question is how do i hook up the harness? i wont have the driver side connector anymore so will i still be able to run my tpi harness or will i have to order an expensive a$$ tpi harness?
Old Sep 6, 2011 | 08:42 AM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Re: tuned port swap
here are the parts im going to be using
http://www.summitracing.com/parts/SUM-SBCKIT1-300/
thats the engine rebuild kit i want it will be a .030 over so im told thats a 355.
http://www.summitracing.com/parts/SUM-890020/
thats the wiring harness for the car i will be using.
i also want to cam it. i want it to be mild with a decent idle. i dont know whats too big for a tpi with stock plenum runners and manifold. nothing will be ported.
Old Sep 6, 2011 | 08:05 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: tuned port swap
unless the inside wiring on the car is completely shot or rigged, i wouldnt bother with the summit wiring kit. its gonna be a pain to rewire EVERYTHING in the car.
as for the tpi setup, as long as you get the wiring and ecm with the intake, itll be a direct bolt in. the engine wiring is seperate from the rest of the car.
Old Sep 6, 2011 | 09:20 PM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Re: tuned port swap
yeah the chassis harness in my car is done for its all cut up and theres shorts in it plus the connector pins are all messed up. none of the gauges work and it kills batterys over night so i was told that im gonna need a new harness. i seen other builds where they make it look so easy. so your saying if i do the harness swap then the tuned port wiring from a stock fbody would still work without having to be connected to the driver side bulk head connector?
Old Sep 6, 2011 | 09:21 PM
travis401's Avatar
Car: 91 Camaro RS
Re: tuned port swap
the ecm wiring doesnt connect to the driverside harness at all.
Old Sep 6, 2011 | 09:25 PM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Re: tuned port swap
i know but i was looking at the entire wiring with all the tuned port stuff it runs from passenger side to driver side to that connector
Old Sep 6, 2011 | 09:43 PM
travis401's Avatar
Car: 91 Camaro RS
Re: tuned port swap
theres a few wires that run through the loom behind the motor, but none of them go to the driver side bulkhead connector
Old Sep 6, 2011 | 09:57 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: tuned port swap
get a harness from a car in the salvage yard, it'll already be set up. nobody really takes the underdash harness. also unless you're using a larger oil pan, get a standard volume oil pump. use melling m155 with the matching pick up. It's a 3/4" pickup tube. what year intake are you picking up? that'll depend on what heads you can use.
Old Sep 6, 2011 | 10:04 PM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Re: tuned port swap
ok so maybe my plan will change. when i get a tuned port intake and harness ill just pull the dash harness from the same car at the salvage yard. that will be like 30 bucks for all the wiring! instead of a 300$ kit that might be a pain in the ***. i definitely want to use my stock gauges. i love them for some reason. plus i wont be doing too much strip usage so the stock oil pan should be good. ill just clean it up and spray it or something. i want to have a roller cam engine but i want to try to get an intake from a perimeter bolt engine
Old Sep 7, 2011 | 11:46 AM
Car: 86 Camaro Z28
Re: tuned port swap
If you're looking to buy really soon, I have a set of TPI corvette aluminum heads. they use the old style intake bolt pattern, but they have the centerbolt valve cover holes.
Old Sep 7, 2011 | 12:37 PM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Re: tuned port swap
how much are you looking to get for them? im in maryland, im not sure where your located but if its far would you mind shipping them? im at middle river md 21220. i wont have cash till september 20, im really interested in the heads
Old Sep 7, 2011 | 12:50 PM
Car: 86 Camaro Z28
Re: tuned port swap
I'm in fayetteville, NC. I'll PM you with pricing and shipping.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
nuggie
Aug 25, 2015 01:27 PM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
