Possible LT1 engine.
Old Sep 15, 2011 | 02:22 PM
  #51
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Re: Possible LT1 engine.
Originally Posted by lunati397
30 over cam --- no such thing he had the block bored 30 over and maybe has a cam if he told you it was a 30 over cam he didnt have a clue what he was talking about and if the block was bored over then he would have gotten pistons and did alittle more to the motor
just for the sake of it maybe he got a truck engine 350 tbi and put it in it maybe even a 1500 LT (maybe where he got the lt1 from) "yeah jimbo thats one of them lt ones"
and as my old shop teacher told me way way back in the day when I got my RS 305tbi camaro if you consider your grandma pushing you in a shopping kart fast then its fast but until you really know what fast is you will believe it is
Just re-read this it makes perfect sense
Old Sep 15, 2011 | 02:41 PM
  #52
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Originally Posted by xxZ28xx
They said they pulled it out of a corvette, You have a pic of this engine?
Sorry, no pic. Do you know what year of corvette? If I recall correctly, 1992-97 was the LT1 and 1969-73 was the LT-1.
Old Sep 15, 2011 | 02:46 PM
  #53
xxZ28xx's Avatar
well I just got the thing off the block it said GM 5.0 so im guessing its just a 305 for now... So they either didn't know what an LT1 engine is or just lied to me.. Idk what the point of lying would be though I didn't spend to much on the car lol. I dont know what year he said..
Old Sep 15, 2011 | 07:55 PM
  #54
murukalo's Avatar
Car: 1988 Camaro RS
Engine: 355
Transmission: TH-350
Axle/Gears: 4:10
well the clanking could possibly be a U-Joint but that would only make noise in drive or reverse. it could be an engine knock if it does it while idling, could be an exhaust leak or even a bad lifter. Heres another question, where are you located maybe someone close by could stop and help you out
Old Sep 16, 2011 | 04:04 AM
  #55
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
What exactly is the u-joint?
Old Sep 16, 2011 | 07:42 AM
  #56
torque_is_good's Avatar
not an insult but, basic knowledge is needed and you need to get it. We're going to use acronyms and terms and you need to understand at least where in the vehicle we are discussing
http://www.amazon.com/s/ref=nb_sb_no...mies&x=17&y=18
if your dad, uncle, girlfriends dad, high school teacher whomever is knowledgable, maybe they will take 15-20 minutes and go over what the items are under the hood, under the car and their purpose. It need not be detailed.
Then, buy them a Subway and a drink, it would be money well spent.
Old Sep 16, 2011 | 07:49 AM
  #57
hold on!!!!!
clanking??? what clanking? did I miss something?
I feel for you. You've learned a valuable lesson that you must bring a knowledgable person with you when looking at used vehicles and you can't buy with emotion. You were told LT1 engine when it's a plain jane LO3 and now you have a clanking?????
please describe in as detailed as possible what exactly is going on.
Is the vehicle even on the road? How does it ride? How does it track? How does it shift?
We're here to help you but you are our eyes and ears and you need to get up to speed as quickly as possible.
Sure, maybe you got a screwing by the seller but time will pass and the vehicle will live again.
We parents might be pains in your butt but our experience is valuable and you really need to enlist our services or risk spending way too much for goods and services because many of us learned the hard way.
Old Sep 16, 2011 | 12:24 PM
  #58
xxZ28xx's Avatar
hahah I really appreciate the help! This is exactly what I wanted, but I fixed the problem. The valves were loose. Really really really loose =D I tightened them up and bam it runs perfectly even switching into reverse and drive is a lot smoother now. Its not on the road yet just because when I bought it it wasn't in to good of shape. Well with the knocking and all that so I was a little iffy about driving it yet. All I need now is tires and Im getting them next friday (and registration, etc.). I have big plans for this car been wanting a Camaro since I was a kid.
Oh another issue Im having is in another post: https://www.thirdgen.org/forums/tran...ttom-pics.html
But I drove it one time and that was from St. Pete back to Clearwater where I live which really is not that far. But even with it being all messed up it still ran great, until I ran out of gas and the battery wire almost lit on fire. They everything all "rigged" in the car. So I took like 15 mins out of my life to go buy a new battery with terminal wires as soon as I turned my car on it was like giving it new life. The air/heat came on and was blowing strong (it didn't even work before), and my car starts right up. I don't think they knew to much. I pulled the engine codes and it told me I needed a temp sensor so I bought one because it was broke and it started running even better (smoother) Except for the clanking. Which they told me was my exhaust because they ran into something and bent it, so I have to bend that back. But my exhaust is pretty secure on there so that got me worried. Yesterday I just took the valve covers off to get the GM 5.0 off the block and called my one friend over ( he has knowledge in motors and stuff like this just not to good with all the electrical stuff. Hes more of a boat motor guy but he moved my valves around an they were loose. The 6th cylinder intake and exhaust were really loose. It felt like there was no tension at all, so I followed my haynes manual tightened them and started it up and I accidentally put one on to tight and it ran horrible for a second but I loosened them all a quarter of a turn and started right up better than it probably ran in a while. This is the coolest thing ever because I thought I was gonna have to take the engine all apart. ( I would like to do this but not to this engine I would like to actually buy an LT1 or just a 350 and put it together like a kit Im sure they sell them somewhere.)
I think they just wanted to get rid of the car. They lied about an LT1 engine but I didnt really pay for an LT1 car, I just payed for a used car pretty much. They probably thought it was about to blow (because he said his mechanic did some engine work Im assuming didn't tighten the valves correctly or missed one because 6 was just crazy loose.) Then he gets it back and thinks its done. You could also tell its been sitting for a while because the tires were pumped up when I got there and not even 20 mins after leaving there they started deflating haha. He was originally at 1800 and I got him down to a 1000 but he wasn't too hesitant I kinda wish I asked 900-950 at least I would have had enough money left over to buy some tires.
What size tires should I get (I have to buy used for now so idk if they will be there). I want my car to look like a muscle car and I just bought this one tire and it looks littler than all the others so Im just going to buy 4 used ones but need to know a nice size.
Thank you.
Old Sep 16, 2011 | 12:27 PM
  #59
xxZ28xx's Avatar
Oh wow forgot about my whole vin issue. Saying I have a Z28 when other people are saying its not a Z28.
Old Sep 16, 2011 | 01:45 PM
  #60
Thank you.
please start a thread in the engine tech section
anyway
grab a multimeter from somewhere or someone
measure the voltage between your positive and negative battery terminal. Let's say you measure 12.3 volts
then, measure it with the engine running. If it remains 12.3 volts then either
A; bad alternator
B: no wire going from alternator to the positive connector block near the radiator
that might explain why no accessories were working, you didn't have enough voltage and were running off of the battery.
You should be reading over 13 volts when the engine is running
tires- we have no clue what rims you have so go read the sidewalls and buy the same size
nextag.com is a great place to compare prices
and I'm waving to you from Sarasota
Old Sep 16, 2011 | 03:56 PM
  #61
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dont recall vin numbers indentifying explicity Z28 or RS or coupe or whatever.
What all does the VIN say? Run it on carfax. If it doesnt match the car...
Check the stickers in the door jams and compare those to the one on the windshield.
Old Sep 16, 2011 | 04:00 PM
  #62
AmorgetRS's Avatar
Carfax WILL NOT be able to tell you if the car is a Z28 or an Sport Coupe/RS. Being it's a TBI car, it can be either. This was all explained in his other thread. If it has the small spoiler on it instead of the 3 piece, assuming it is stock, it is not an IROC as that spoiler was not available on the IROC. There is no "Z28" in 88, only the IROC. Z28 was the RPO for the IROC package, but the separate Z28 and IROC package was dropped after 87.
Old Sep 17, 2011 | 10:18 AM
  #63
xxZ28xx's Avatar
I have a 3 piece spoiler?
Old Sep 17, 2011 | 10:21 AM
  #64
xxZ28xx's Avatar
anyway
A; bad alternator
Oh wow your not really that far away, pretty cool! My rims are 15's. Yeah I don't know if my battery gauge works but it does read over 13 when I have it running. Its a brand new die hard battery with 690 CCA.
Old Sep 17, 2011 | 12:45 PM
  #65
AmorgetRS's Avatar
Ok, so it falls under to could be an Sport Coupe, or a could be a Z28.
What does the emblem on the gfx say?
Old Sep 17, 2011 | 10:08 PM
  #66
xxZ28xx's Avatar
Whats a GFX?
Old Sep 17, 2011 | 10:18 PM
  #67
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Whats a GFX?
GFX is the general short term for Ground Effects.
Originally Ground Effects were designed to smooth and cut airflow from under the car, decreasing drag and increasing downforce without the penalty of a spoiler or wing.
See this picture of the Ferrari Enzo's underbody to see what I mean about a body tray, then go look at what the floor of a thirdgen looks like in comparison. Now ricers use them as "body kits" and little if any thought is given to aerodynamics.
another basic article: http://www.hotrod.com/techarticles/b...s/viewall.html
Old Sep 17, 2011 | 10:50 PM
  #68
xxZ28xx's Avatar
Is this somewhere on my car. The floor?... the inside, or underneath the car? thanks
Old Sep 17, 2011 | 10:57 PM
  #69
for the purposes of being installed on a thirdgen GFX are basically a body kit consisting of a nose with an integrated chin spoiler, fender, rocker panel, door moldings, as well as a different bumper usually.
Firebird Formula's dont' have GFX: http://www.performance-car-guide.co....rd-formula.jpg
TransAms do: http://www.carbuyingtips.com/pics/GTA1.JPG
Old Sep 17, 2011 | 11:15 PM
  #70
xxZ28xx's Avatar
Oh it just says Camaro, You know I looked on this site and there was vin decoder, you know for each letter in the vin. It said it was a sport coupe, also its one of the first 3000 Idk how many cars were made...
Old Sep 18, 2011 | 12:36 AM
  #71
AmorgetRS's Avatar
Ok, so if we ASSume that the "Camaro" badge is stock, then you have a Sport Coupe, not a IROC. The IROCs said IROC-Z iirc
Old Sep 18, 2011 | 02:36 PM
  #72
xxZ28xx's Avatar
I did the manual vin thing on this site and it said I have a sport coupe also, I like the style of it, and it has a 3piece wing. Idk These have been my favorite cars for ever so Im pretty happy I have one now. My ultimate dream car 69 camaro cant wait untill I get that. I hope to have a lot more experience by this time. Thanks for all the help guys.
Old Sep 19, 2011 | 12:23 AM
  #73
AmorgetRS's Avatar
What manual vin thing on this site? I will repeat this for the 3rd time, the VIN will NOT tell you if you have a Sport Coupe or an IROC.
Old Sep 23, 2011 | 02:36 AM
  #74
Car: 1992 Camaro RS
I think my title states my RS is a "Sport Coupe". Just a generic term.
Old Sep 30, 2011 | 02:55 PM
  #75
xxZ28xx's Avatar
Lol ill never know... It is probably just a camaro...
Old Sep 30, 2011 | 02:59 PM
  #76
Car: 1992 Camaro RS
There are a LOT of ways to find out. Find your SPID sheet with the RPO codes.
Check your sway bar diameters.
Check for a wonderbar.
What's your dashboard say? Camaro or IROC/Z28 or Z28?
All of those can be added or removed, but at some point it will begin to become obvious what it most likely was.
Im pretty sure your car is one of the early Rally Sports. Im just not sure why it has the 3-piece spoiler instead of the goofy low-rise 2 pylon spoiler.
Old Nov 9, 2011 | 11:46 AM
  #77
xxZ28xx's Avatar
Questions that will never be answered lol.. Someone said I can call a chevy dealer and they can just tell me what it is Is that true?
Old Nov 9, 2011 | 06:15 PM
  #78
AmorgetRS's Avatar
No, the Chevy dealership at this point won't have any more information then we do.
Old Nov 11, 2011 | 05:13 PM
  #79
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
lol...this is a funny thread good luck dude!!
Old Nov 15, 2011 | 10:23 PM
  #80
TopdownIroc's Avatar
Car: 1990 IrocZ Convertible
Engine: TPI 305 (factory & anemic)
Axle/Gears: Crappy factory 2.73
Judging by what I read by the OP, I'd say the dumb••• people meant to say they bored the block .030 and possibly added an LT1 cam. The LB9 motor is a roller motor so the LT1 roller cam would definately work.
88SS6SPEED
Nov 11, 2015 07:05 AM
David Frans
Oct 31, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
WejaZ28
Oct 3, 2015 07:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
