'87 camaro 2.8L V6 swap to V8 suggestions and tips.
Old Sep 14, 2011 | 09:05 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
I have a '87 Camaro with v6 and would like to swap to V8 but have no clue what would be best. What motor, tran, rear end, and so on. Needs to be budget friendly. thanks for the tips. Jesse
Old Sep 14, 2011 | 09:58 PM
1gary's Avatar
Re: '87 camaro 2.8L V6 swap to V8 suggestions and tips.
Feel yourself lucky Jesse.Your going to be the benefit of in the last three wks of people that have asked the same thing.
How Much Money Do You Have To Spend???. Let's Start There.
Old Sep 14, 2011 | 10:04 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Not much right now close to 1200. I know how to build motors and such but I just can't think of a good combo. I mainly want to get good v8 to build from just so I can drive my car again. So I need the basic's motor, tran, engine harness, probably a new computer and so on.
Old Sep 15, 2011 | 01:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
sell the v6 and buy one with a v8 already in it. itll wind up being cheaper in the long run.....
Old Sep 17, 2011 | 09:40 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Agreed, however if you still decide to do the swap, $1200 isn't likely to get you very far. The short list of things you'll need is the motor, trans, computer & harness, v8 front coil springs & sway bar, v8 radiator and more. Your best bet is to find a good running wrecked/rusty thirdgen with the motor & trans you want, but that could take a while.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
InfinityShade
Aug 22, 2015 08:00 PM
84Camaro305
Feb 27, 2002 05:58 PM
DEEPSOUTH90RS
Apr 16, 2001 02:17 PM
