Engine wiring harness
Old Sep 18, 2011 | 06:13 PM
RenoMichaels's Avatar
I have an 1987 iroc. That was a TPI. I'm changing it over to a carb. What if any part of the wiring harness do I have to keep in the engine compartment.? Thanks.
Old Sep 18, 2011 | 06:59 PM
92CamaroKyle's Avatar
Car: 1992 Camaro RS
Engine: LS 1
Axle/Gears: 10 Bolt 2:83
Re: Engine wiring harness
I would think you need a keyed 12v to your distributor a ground to your tach and temp/ fan sensor wires.
Old Sep 18, 2011 | 09:51 PM
So would you think that I would be able to remove the existing wiring harness?
Old Sep 20, 2011 | 08:11 AM
Car: 1992 Camaro RS
Engine: LS 1
I would pull it out and start over with just what you need. Easier to wire up and looks alot cleaner. Plus you could sell all as a package. Have you figured on reducing fuel pressure for the carb yet?
Old Sep 20, 2011 | 08:36 AM
Well i dont want to cut out the harness until it fires up and everything is working fine. Whats your thoughts on reducing the fuel pressure? Are you talking about from the fuel pump?
Old Sep 20, 2011 | 09:42 AM
Car: 1992 Camaro RS
Engine: LS 1
You will need a regulator on the line before the carb. Most carbs only need 7-9 psi and if you are going from fuel injection to carb you have to reduce the psi.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
