What is to the right of the heater motor?
Old Sep 19, 2011 | 10:02 PM
RenoMichaels's Avatar
Does anyone know what is mounted on the firewall to the right of the heater motor. In front of it is a silver cylinder. Are either of them a necessity if swapping to a carb engine from TPI? No interest in bells and whistles just want the car to run and drive. I'm looking to clear engine compartment of all unuseful things. Thanks
Old Sep 19, 2011 | 10:19 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: What is to the right of the heater motor?
Evaporator core?
Old Sep 19, 2011 | 11:16 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Sounds like the evaporator core.
Old Sep 19, 2011 | 11:24 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
^^^ +1
Does it have 2 pipes coming from it, top and bottom? If so, the guys above me have nailed it.
Old Sep 20, 2011 | 07:36 AM
The part that I am referring to is attached to the fire wall and then attached to it on the front has that silver canister that has some tubes coming off of it. Im sure the silver part of it is the evaporator core but what about the part that is attached to the firewall? And are either of them something that i would need if i am swapping over to a carb and only wanting the necessary components in the engine compartment?
Old Sep 20, 2011 | 08:02 AM
I added this picture to help show what i was talking about..Thanks again[IMG]file:///C:/Users/Andrew/Pictures/Clip%20Art%20Added/Iroc%20Engine1.jpg[/IMG]
Old Sep 20, 2011 | 08:03 AM
Something tells me that the picture didnt post..
Old Sep 20, 2011 | 05:57 PM
No picture posted but I'm still assuming what your talking about are A/C components. If you dont plan to keep A/C then they are not necessary for your motor change.
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
greenyone
Aug 29, 2015 11:08 AM
TheExaminer
Aug 26, 2015 04:59 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
