Doing V6 to V8 Swap. Need Info
Old Sep 20, 2011 | 04:10 PM
Georgiaboy6985's Avatar
Car: 89 Chevy Camaro RS
Engine: 2.8 V6
Transmission: Manual T-5
I got an 89 Camaro RS with the 2.8L v6 in it and 5 speed tranny. Im going to install a carburated 350 with a HEI Distributor with vaccuum Advance. Only question is, The wiring harness that came witht he v6, can i remove it or do i still need some of it? like for the guages and things like that. Also how exactly do u hook up the HEI ignition?. Id like to cut and get rid of as many wires as i can to clean it up. Already got rid of the AC system. Just need help as far as the Carb vaccuum lines and HEI ignition. Any help would be appreciated. I already got the motor. Just waiting for some mroe info before i put it in
Old Sep 20, 2011 | 08:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Doing V6 to V8 Swap. Need Info
Welcome aboard thirdgen.org.
Step 1 is to read the V6 to V8 swap sticky in the top section of this forum:
https://www.thirdgen.org/forums/engi...swap-read.html
$750 L98
Feb 1, 2025 02:25 PM
3rdgenparts
May 21, 2016 11:50 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
usafirebird
Sep 29, 2015 11:58 PM
