ENGINE QUESTIONS 1994 ROADMASTER
Old Oct 15, 2011 | 02:06 PM
1983GMC's Avatar
I HAVE RECENTLY PURCHASED 1994 RAODMASTER 350 AND TRANNY TO INSTALL IN MY 1983 GMC PICKUP. IT DOESNT HAVE THE WIRE HARNESS.
MY QUESTION IS IS IT WORTH GETTING THE WIRING HARNESS FOR IT AND KEEP IT ELECTONIC OR WOULD IT BE BEST TO MAKE IT CARB.
2ND Q. WOULD I HAVE TO GET THE HARNESS AND COMP. TO A ROADMASTER OR WOULD AN IMPALA SS HARNESS AND COMP. WORK IN IT ASWELL.
Old Oct 15, 2011 | 07:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ENGINE QUESTIONS 1994 ROADMASTER
Keep it EFI
For your installation a aftermarket standalone harness would be easier.
Saves having to gut out unwanted wires from a stock LT1 harness
Only have batt , ign and fuel pump wires to hook up to your pickup.
something like this one for LT1 with elec trans
http://www.ebay.com/itm/1994-95-LT1-...item2c5fd460e7
Looking at eBay pricing you will pay as much for a stock harness
Old Oct 15, 2011 | 10:08 PM
1983GMC's Avatar
THANKS FOR THE INPUT
HOW WOULD I KNOW IF THR TRANNY IS ELECTRIC?
I SEE A CABLE THAT RUNS TO THE THROTLE.
Old Oct 15, 2011 | 10:44 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Non elec 4L60 has the cable.
Elec 4l60E looks identical but has no cable hook up.
Has a elec connector on pass side that 4L60 doesn't have
(Still need to run a wire to operate the torque convertor lockup on your ) 4L60
Non elec trans LT1 standalone harness is cheaper
http://www.ebay.com/itm/1994-95-LT1-...item2c5fd46048
Old Oct 15, 2011 | 11:05 PM
1983GMC's Avatar
THANX AGIAN VETTEOZ
SINCE THE THROTTLE BODY IT HAS IS STUCK CAUSE OF THE TIME IT WAS EXPOSED TO THE ELEMENTS OF THE TIME THE ENGINE WAS PULLED FROM THE BUICK IT IS COMPLETELY SHOT.
WOULD IT BE A GOOD IDEA TO GET A INTAKE MANIFOLD AND THROTTLE OF A CAMARO, OR WHAT INTAKE AND THROTTLE WOULD BE A GOOD PURCHAS. JUST SO U GET AN IDEA OF WHAT IM TRYING TO ACCOMPLISH.
IM TRYING TO GET 300-350 HP ATW, I'M PLANNING TO INSTALL A NICE CAM NOTHING TO RADICAL, AND DO A LIL WORK TO THE HEADS.
Old Oct 16, 2011 | 01:41 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As far as I am aware there is no difference in the LT1 intakes except which side the fuel rails are fed from.( the fuel rails interchange anyway ) so what ever is cheapest will work
Old Oct 16, 2011 | 07:53 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
With a cam you would need a tune for sure.I would pass on the cam.Get the heads worked on throw some LTs on it and call it a day.
Old Oct 16, 2011 | 12:04 PM
1983GMC's Avatar
THANX FOR THE TIPS GUYS
I GUESS MY QUESTION IS CAN I GO FROM A TBI TO A TPI SET UP ON THIS ENGINE?
Old Oct 16, 2011 | 12:36 PM
gmstrong's Avatar
I thought you said you had a LT1 if so why are you talking about TBI?
Old Oct 16, 2011 | 04:39 PM
1983GMC's Avatar
SORRY GMSTRONG
I HAD MY FACTS WRONG.LOL
WHAT I HAVE IS A 350 TBI OFF A BUICK ROADMASTER MY QUETION IS WOULD IT BE POSSIBLE TO CONVERT IT TO TPI?
Old Oct 16, 2011 | 05:44 PM
gmstrong's Avatar
So its TBI now and you want to convert to TPI,Anything is possible but will be time and money consuming TBI is a good system and i doubt you would gain any hp if thats what you have in mind.You would need to get a whole TPI harness since it has a MAF and other newer parts.ALOT of time and whole **** load of money for no reason.Dont bother buddy.
Old Oct 16, 2011 | 10:50 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Forget everything I said above
Old Oct 16, 2011 | 11:11 PM
1983GMC's Avatar
THANX FOR THE INPUT GMSTRONG
YEAH VETTEOZ SORRY FOR THE CONFUSION BUDDY WHAT I HAVE IS A 350 TBI SYSTEM.
NOW MY NEXT QUESTION IS WHAT CAN I UPGRADE TO GET A FEW MORE HORSES OUT OF IT?
ALL TIPS ARE GREATLY APPRECIATED.
THANX AGAIN GUYS
Old Oct 17, 2011 | 01:04 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Ask in TBI Dept
https://www.thirdgen.org/forums/tbi/
https://www.thirdgen.org/forums/tbi/...mods-info.html
https://www.thirdgen.org/forums/tbi/...-tbi-what.html
https://www.thirdgen.org/forums/tbi/...i-buildup.html
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
