n00b oil filter question
Car: 89 rs 358 / 99 wrangler 4.0
Engine: 358
Transmission: t5
Axle/Gears: 393 12 bolt
hey ive got an 89 camaro with a 358 in it, just wondering what you guys use as far as oil filters? ive had the car a year and half now and havent really driven it, i want to change the oil tho since its past due as far as time goes, i want to get it fixed up and ready to go over the winter and ready to drive in the spring
part numbers would be awsome!!
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: n00b oil filter question
Wix or NAPA Gold (rebranded Wix)
No Fram. No STP.
If you don't have an oil cooler tell them you want one for a truck, it's taller.
No Fram. No STP.
Engine: 358
Transmission: t5
good tip on the truck thing thanks, i never use fram seen the pics of the inside of their filters lol! thanks again,
just looked it up, WIX 51060 sound right?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I like AC Delco PF 1218.
JamesC
JamesC
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I thought I heard that AC delco was being manufactured by a different company and that the quality had slipped? Any truth in that?
I usually run either a WIX, Bosch, or Mobil1. Sorry no part numbers. I make sure mine are the taller units too.
Engine: 358
Transmission: t5
sorry about the long response time, noone around me had a WIX filter, and there are no NAPA's (that i know of) close to me so i went with a mobile 1 filter for a 79 C10, fit perfect, also got some new plugs, previous owner had some stupid bosch platinum +4 plugs in it, went with some champion plugs since i have always used them and never had a single problem, also put some nice drilled header bolts in so i can saftey wire them today, PO had some ghetto bolts it looks like he found in his tool box and cut down to size with tin snips in there lol, needless to say they came loose a lot, thanks for the replies!
I have never seen Bosch Platinums run right in an SBC.
I'm not the biggest fan of Champion plugs, but I'm sure they'll work.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I normally use a System 1 reusable filter on my race car. Easy to take apart and inspect.
Moroso, K&N, Mobil 1 or any WIX made filter. There's only a few actual filter manufactures who make all the filters you see on the shelves. Fram does not make oil filters. I wouldn't use a Fram filter if it was free unless it was an emergency.
For an unbiased opinion on anything to do with oil, check out this site
http://www.bobistheoilguy.com/
Although the information is getting a little outdated, information about different filters can be found here.
http://minimopar.knizefamily.net/oilfilters/index.html
http://minimopar.knizefamily.net/oil...reference.html
Engine: 358
Transmission: t5
ya i HATE them, it runs MUCH better now, i used to have an S10 with the vortec V6 and the guy at autozone talked me into buying the bosh platinums. took them back and swapped them for champions about a week later lol!
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
On my IROC, I use a K&N 3002. It's a longer version of the 2002 mentioned above. Whether or not the filter is any better than a cheap Wix/Napa filter, I couldn't say, but since I only change the oil on the IROC once every year or two, a standard filter winds up being difficult to remove. The K&N has the nut on the bottom that makes removal a snap.
Engine: 358
Transmission: t5
I can't speak to the quality, but visually, the new 1218 looks like a cheap piece of crap. I stockpiled them when they became available again, then upon first use discovered that it's built nowhere near the same way the old one (which I still had a few of). I've since converted all of my 1218-equipped cars to WIX/Napa filters.
Car: 1987 Trans Am
Engine: LQ9/L92
always used purolator filters without issue. usually ran the truck filter for a little more filtering area and a tad more capacity too.
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
The 3002 is bigger, but fits just fine -even with my long tube headers.
Part HP-3002 Product Specifications
Product Style: Oil Filters
Height: 5.7 in (145 mm)
Outside Diameter: 3.69 in (94 mm)
Thread Inside Diameter: 0.81
Thread Number: 16 UNS
PSI Relief Valve: None
Anti Drain Back Valve: Yes
Style: Canister
Removal Nut: Yes
Gasket Material: Nitrile Rubber
Filter Material: High Flow Premium Media
Bypass Valve: No
Weight: 1.4 lb (0.6 kg)
Product Box Length: 3.81 in (97 mm)
Product Box Width: 3.81 in (97 mm)
Product Box Height: 6 in (152 mm)
Part HP-2002 Product Specifications
Height: 4.7 in (119 mm)
Outside Diameter: 3.68 in (93 mm)
Anti Drain Back Valve: No
Style: Canister
Removal Nut: Yes
Bypass Valve: No
Weight: 1.2 lb (0.5 kg)
Product Box Height: 4.88 in (124 mm)
Style: Canister
Removal Nut: Yes
Bypass Valve: No
Style: Canister
Removal Nut: Yes
Bypass Valve: No
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
