Vette L98 into TBI car
Old Oct 30, 2011 | 03:42 PM
jk92's Avatar
Car: 1992 camaro rs
Engine: 305 tbi (lo3)
Transmission: 4l60e
Please help I have l98 from 86 vette .I would like to put it in my 92 l03 car what do i need
Old Oct 30, 2011 | 03:58 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: L98 Swap Finished
you have nearly everything you need, you pull the old engine, swap over everything to the new engine and bolt the new engine back in.
the only new part youll need is a 350 knock sensor and a 350 prom, (if you dont have the 350 ecm). itll run, but wont run its best with the 305's tbi. theres a few of threads around here about putting the tbi on top of a 350.
Old Oct 31, 2011 | 09:23 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
What is a 350 Prom?
Old Oct 31, 2011 | 09:26 AM
travis401's Avatar
Car: 91 Camaro RS
its the chip in the computer that basically stores the tune.
Old Oct 31, 2011 | 09:43 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You will need a harness for tpi or at least re-pin your existing one.. There are threads on here that cover that.
Old Oct 31, 2011 | 09:47 AM
travis401's Avatar
Car: 91 Camaro RS
is he keeps the tpi from the vette, hell have to use the ecm from the same vette, which if hes got that, chances are hes got the harnes as well.
if you dont have the ecm or harness for the tpi, youll need both. or just an ecm from a tpi 350 and repin your harness. or you can rework your stock tbi and use it with the stock harness and computer with a little bit of work.
Old Oct 31, 2011 | 10:30 AM
ninetyone's Avatar
Axle/Gears: 3:42
Any 730 ecm will work, it doesn't have to be for a 350 tpi.
Old Oct 31, 2011 | 10:35 AM
travis401's Avatar
Car: 91 Camaro RS
eh, im not too good with the computer crap, i ditched mine a while ago
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
matthew911
Aug 12, 2015 09:38 AM
