Chevy 1500 engine swap questions?
Old Nov 21, 2011 | 09:09 AM
mightydunk's Avatar
Car: 1990 Iroc-z Camaro
Engine: 5.7L
Transmission: Automatic
so i purchased a 5.7L engine from a guy who was putting it in his 1993 chevy 1500 after his first engine siezed up on him. He said it was made by a company named Rhino and he only drove it about 25 miles, anyway its a reproduction of the origonal motor and i plan on it going in my Iroc, any thing that might stop me or i might run into? also what would be some big torque increasers i was thinking a comp cam and boring it out let me know thanks
Old Nov 21, 2011 | 02:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't bore an engine to increase the power. You bore a worn engine during a rebuild to restore the cylinder wall surfaces.
I assume you have TPI. Put that system on a truck 350 and you'll have about as much torque as possible.
Old Nov 23, 2011 | 05:50 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Chevy 1500 engine swap questions?
The most you'd be able to bore it is .040 inches, which is all of 7 cubic inches. As has been mentioned, the cylinder walls are fairly thin. You only bore it out enough to get the cylinder walls round again and if you can get away with only boring it .010 over - do it.
Old Nov 23, 2011 | 06:39 PM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
are you keeping it tpi the 350 would be tbi i swapped my 305 tbi for a 355 tbi its a easy swap that way mine was a 91 305tbi and a 87 350 (.30 over) there were no issues at all for me
Old Nov 23, 2011 | 06:58 PM
Car: 1992 Camaro RS
.3 inches is HUGE difference. What you mean is .030 over. GM says .030 is the limit for factory blocks, realistically .040 is fine usually, the next step is .060. I've had a .060 over block bite me before - never going to run a .060 over block again unless it's an aftermarket block.
Old Nov 23, 2011 | 07:14 PM
lolvtec's Avatar
Axle/Gears: 2:73...
lol my bad i ment .03
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
