v6 to v8 questions
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
v6 to v8 questions
how difficult is it to convert a v6 fi to a tbi 350? would i just have to replace the v9 ecm and wiring with a tbi ecm and harness?
Transmission: 4L80E/4L80E
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: v6 to v8 questions
cant forget the v8 trans. the v6 trans wont bolt to the v8.
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
I switched out the fuel pump to cause I swapped from a v6 to tpi v8 5.7 which I knew requires higher pressure then the tbi, but its something to double check.
