driveshaft help
Old Dec 23, 2011 | 12:31 PM
rczanstke's Avatar
driveshaft help
So I swapped my 305/700r4 for a 350/th350 with the shorter tailshaft. The engine/trans are in. I just have a couple questions.
1. Is the driveshaft for the th350 the same length as the driveshaft for a th200?
2. Is there another vehicle with a driveshaft that I can use for the camaro?
3. If the answer to question 1 is yes, where can I find such a driveshaft, save the junkyard?
Any answers would be appreciated.
Also, it's an 83 z28, if it matters.
Old Dec 23, 2011 | 12:55 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: driveshaft help
https://www.thirdgen.org/forums/faq-...ngth-info.html
Old Dec 23, 2011 | 04:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: driveshaft help
The 700R4 and the long tailshaft TH350 can use the same length driveshaft. A short tailshaft TH350 needs the longer driveshaft from a 82-83 third gen that came with the 200c 3 speed transmission.
It's unlikely you'll find another junkyard driveshaft from something else that's close enough to the same length. You can always take your driveshaft to a driveline shop and have it lengthened.
Since your engine and tranny are already in, get a custom length made. Take the slip yoke off the driveshaft and slide it all the way into the transmission then pull it back out one inch. Measure from the center of the u-joint cup on the slip yoke to the center of the yoke on the diff. That's the driveshaft length required.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
