whats everything else i need for a motor swap beside the motor itself?
Old Jan 5, 2012 | 08:31 PM
87fbodyy's Avatar
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
just picked up a 350 for my 87 iroc from my uncle its carbed but what else do i need for the swap?
Old Jan 6, 2012 | 05:58 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: whats everything else i need for a motor swap beside the motor itself?
do a search for carb swaps. theres tons of them on there with all the info youll need.
Old Jan 6, 2012 | 06:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
is it a one or two piece rear main, you might need a different flexplate. if you are going from a 305 tpi to 350 tpi you will need 22#hr injectors and a 350 memcal or your memcal reprogramed.
Old Jan 6, 2012 | 10:09 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
And, don't forget your checkbook.
Old Jan 6, 2012 | 10:33 PM
Engine: Lb9
Transmission: M20
That's the first thing on the check list !!
Old Jan 6, 2012 | 11:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
and a 350 knock sensor to suit what ECM you are using
Old Jan 6, 2012 | 11:14 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Engine hoist, fluids, someone should list what tools and their sizes too
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
