1986 Iroc-z28 Stock TPI 305 to 383.
Old Feb 2, 2012 | 03:31 PM
86_Stock_Iroc's Avatar
Car: 1986 IROC-Z28
Engine: TPI 305
I'm getting ready to swap my completly stock 305 out for a 383 and would like to keep the stock TPI and use it on the 383, if this is possible what would i have to change other than the fuel injectors and maybe from what i've read an adjustable fuel pressure regulator. i would also like to know of any other modifications that may need to be done as well. any and all advice/insight would be greatly appreciated.
I already have a completly rebuilt 700r4 that came out of a Z-28 with a 383 in it with less than 500 miles on the trany.
Old Feb 2, 2012 | 06:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Understand that the stock TPI is a restriction to a 305. It is flow limited, and can't be "ported" to fix that. The long stock runners limit upper RPM power. Replacing the runners helps, as long as you port the base and plenum to match. But, it still restricts the power potential of the 383.
The Holley/Weiand Stealth Ram solves the problem, both flow and RPM potential. Doesn't cost any more than aftermarket runners, and you don't have to port anything.
You didn't provide any details of the 383, but heads and cam are important, especially the cam. Too much overlap and it won't be happy with you, especially at idle.
Adjustable fuel pressure regulator is more of a tuning aide than a necessity. What injectors you need depends upon the cam & heads.
Old Feb 3, 2012 | 04:21 AM
Car: 1986 IROC-Z28
Engine: TPI 305
Re: 1986 Iroc-z28 Stock TPI 305 to 383.
The heads on the 383 now are 64cc aluminum heads and 2.02 1.60 int/exh valves not sure about the brand... the cam has a 280 to 292 advertised durration, the durration at .050 is 230 to 240, the lift is .465 intake and .472 exhaust.
i also have a set of aluminum pro-comp 64cc heads that are 2.02 and 1.60, a 670 holly carb, edelbrock highrise ram air gap intake, an msd distributer and everything except the 6al ignition box. would this be a better setup to go with as all parts are new.
Old Feb 4, 2012 | 12:06 AM
five7kid's Avatar
That's a lot of cam. The TPI could probably be made to handle it with proper tuning.
I don't have any love for vacuum secondary carbs. A 650 double pumper would out-run the 670.
Whether the Pro Comp heads would be better than what's currently on the 383 depends upon what's currently on the 383.
Old Feb 5, 2012 | 12:13 PM
Car: 1986 IROC-Z28
Engine: TPI 305
would the weiand 7540 or 7540p be a direct bold on replacement or would i need to switch to aftermarket fuel rails, throttle body, ect. ?
Old Feb 5, 2012 | 03:13 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You need the corresponding Holley rails, but the stock TPI throttle body will fit.
Old Feb 5, 2012 | 09:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/alte...gal-whats.html
Old Feb 6, 2012 | 05:00 AM
Car: 1986 IROC-Z28
Engine: TPI 305
thanks alot for that link! i've spent days piling though threads and trying to figure something out, and i finally have a cost efficent and relitively easy way of doing this! thank you to everyone who took the time to help me wrap my head around this hopefully i'll be done with this build by the end of the month and i'll post some pics
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 10, 2015 07:44 AM
