no oil pressure after engine swap
Old Feb 5, 2012 | 02:54 PM
stephen15935's Avatar
i have a standard chevy small block 350 that is not getting any oil to the top end. i have been spinning the oil pump with a drill and is getting pressure out of the oil filter and the 3 holes above the cam cap, and thats about it. even when the engine was running with the valve covers off, it would slowy slowly ooz out of some of the rocker arms.
it currently has a new high flow oil pump on it and a new oil filter.
i cant think of anything els but a blockage. any ideas?
Old Feb 5, 2012 | 07:05 PM
ex-x-fire's Avatar
Re: no oil pressure after engine swap
Are you using a priming tool? The sbc distributor has a passage that connects the main oil feed lines in the top. The priming tool has that passage.
Heres a picture of a gutted distributor, you'll see the oil passage groove.
Attached Thumbnails no oil pressure after engine swap-img_3222-oilpumptool.jpg
Old Feb 5, 2012 | 09:01 PM
MadCelt's Avatar
Yup. If you are using the 'screwdriver' trick, or a single seal tool, you won't get oil up into the heads. If using a tool, make sure it's got two 'seals', such as this Moroso tool in pic.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
