383 stroker swap estimate numbers?
Old Feb 18, 2012 | 12:39 PM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
383 stroker 1992 Camaro HSR Match ported
58mm TB
38Lb Bosch Injectors
3/4 Hooker LT Headers
Walbro 255 fuel pump kit
Tci flexplate
Msd custom wireset
Ngk Sparkplugs
Tuff stuff waterpump
Pro built 700r4
Moser 9 4th rear end
4.11 gears
Compression 11.6:1
Rockers 1.6Heads.
220cc RHS don't know flow numbers yetCam.
Speed proIntake duration 244@50Exhaust duration 254@50Intake lift 510@50Exhaust lift 533@50112 LSAAdvance intake duration 318Advance exhaust duration 328.
Car is a fully interior 92camaro. What would you guys say the et 1/4 would be. If anyone has a setup like mine please let me know. Thanks
Old Feb 18, 2012 | 01:48 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 383 stroker swap estimate numbers?
stock suspension I'm assuming?
Old Feb 18, 2012 | 02:23 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Yes the suspension is all z28 stock. But will b upgraded after swap is completed.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
bellez77
Sep 5, 2015 08:39 PM
Mickeyruder
Sep 2, 2015 02:45 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
