Casting numbers..HELP!!
Okay so i bought a what i think is a 350 for my 89 RS, but after my buddy told me to run the casting numbers it said it was a 327. I cant find the VIN number as to i have no clue where it would be since all i have is the block. The only numbers ive found were 3970010 K2 and K11 10 CMJ. and on the side i found markings that say 5 L 7. Can someone please help me out here and tell me what i have
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Casting numbers..HELP!!
Welcome to TGO
The 010 blocks are a 4" bore. 302, 327 and 350 engines all used that block. The only way to know the displacement is to find out the stroke.
CMJ was used in 2 different castings. A 1980 305 and a 1974/75 350. Since you have a 4" bore casting, the engine is a 350 unless someone changed the stroke.
Car: 87 IROC L98
You'll only find a partial vin number on the engine in the same place as those stamped numbers are. They won't mean much since the engine probably isn't original any more and won't tell you exactly what it came from. You have a 74/75 4" bore block. After that, the only way to know what's in the engine is to strip it down for inspection.
Well the guy i bought it from said its bored .30 over, the block is all stripped down, it is only block, cam bearings and freeze plugs. The only thing i found in the back was 010 and 979
And the only thing stamped where i found the engine code was that 3970010 number and K2, nothing else but the 010 and 979 number was where the transmission bolts up to
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
3970010 is the most common 4" bore block with a 2 piece RMS. There's nothing else on the outside of the block that will tell you any more about what's inside.
A 327 and a 350 are THE SAME BLOCK. What you have is NEITHER right now, because the difference is, THE CRANK.
However, the 327 was discontinued after about 72; so since you have a 74ish block, it started out its life as a 350.
You could stick a 302, 327, or 350 crank in it, and it would become one of those things instead of merely a block with a 4" bore. Or even, a crank with more stroke still, and get a 383 or 396.
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
