350 swap tpi questions
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
so I purchased the base GM 350 engine most of you may have seen on Jegs, the 1500$ one. and I will be upgrading this engine before it goes in my car with all new parts, so I do not have to use the old engine.
Things I plan to do:
Jegs mini starter
MSD distributor
Big ***** Thumpr cam
Cloyes timing
Comp rocker arms?
Ram clutches flywheel?
Hooker headers
Jegs alternator
stock 700R4 to T5
new F.I. setup
SO my question is..
1. are these worthwhile upgrades?
2. the engine before was a 305 TBI, is there an easy kit to buy to convert it to a TPI, or am I stuck with tbi.I found a Weiand kit on Hawks but i dont know.
3. if i am stuck with TBI, will I benefit from a Holley 4 BBL tbi? thanks alot this is a handful for me
Jegs mini starter
MSD distributor
Cloyes timing
Comp rocker arms?
Hooker headers
Jegs alternator
stock 700R4 to T5
new F.I. setup
SO my question is..
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: 350 swap tpi questions
OK first. Whats the cam spec?
what heads are on the engine? cc? valve size? ect.
what are you planning to use the car for ?
Whats your HP goals?
And for the efi its self I'd suggest a self tuning from holley or something.
And I would rethink your trans swap. A t5 will not like a lot of HP. maybe look for a t56
Car: 1987 Trans Am and 2009 Jeep Patriot
Engine: 305 Tpi
I agree with the post about the t5, I chewed mine up in my formula with only minor mods. Wasn't that why gm never put them in the 350 l98?
Car: 1992 RS vert
Engine: forged 383
Thumpr: HYDRAULIC ROLLER Street/strip, needs 9.5:1 CR , 2800+ stall, intake, gears, and headers, very rough idle
Heads: Stock Cast iron cylinder heads with 76cc chambers
Complete engine specs, stock 350 Engine Specifications
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-574 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
Car: 1992 RS vert
Engine: forged 383
Is there a special manifold or a kit i can buy for tpi?
Engine: 305 Tpi
I love TPI but unless you already have it there are better options, you'd need the hole setup- manifold, runners, plenum etc, not to mention the wiring harness issues, that cam that came with the motor seems really tame. Good luck
That motor isn't going to give you much to work with. The heads are crap, the pistons are dished, the block is a 2 piece RMS block, and it's got a flat tappet cam. I think you're much better off finding a low mile l31 out of a 96-98 Silverado or van. Then you get vortec heads, a roller cam, and a 2 piece RMS block. That motor has way more power potential, and will get better fuel economy too.
Car: 1992 RS vert
Engine: forged 383
Should i just stick with a 4 bbl tbi then?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you decide to go with that engine ,read these articles on how to put some life
into that base GM engine
New heads to get more compression a minimum
http://www.chevyhiperformance.com/te..._ii/index.html
http://www.chevyhiperformance.com/te...iii/index.html
http://www.chevyhiperformance.com/te..._iv/index.html
Fuel injection is the b etter option but it costs, best bang for the buck is edelbrock air gap and holley 780. I would alumium heads and a hydraulic roller cam as well.
Car: 82 Z28
Transmission: T400
As already noted by Jim85IROC
would be more effective and cheaper in the long run to sell that low comp crate engine
and start with a better base
Roller lifters to convert a flat tappet block are $300+ without the cam cost
That $$$ would be better spent instead on a roller cam block
Car: 1992 RS vert
Engine: forged 383
upgrading the heads with RHS, not sure which ones yet, the timing is gonna be a gear drive no belts or chains, a thumpr hydro roller cam and comp rocker arms. so 4 bbl TBI or tpi swap?
Car: 1992 RS vert
Engine: forged 383
Then a double roller, and i found a guy whod sell everything for tpi including the harness for 350$
Car: 1992 RS vert
Engine: forged 383
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I've read some bad reviews on the thumpr series cam. Some say its only for sound and not so much for performance. Is that motor a roller motor?
Sanjay
08-12-2015 03:41 PM
