Hi guys,
I've been searching for hours and I can't seem to find a straight-forward answer to my question.
I have a 350 with a stock LT1 roller cam in it, but it turns out the 906 Vortec heads that came with the motor were screwed up by the previous owner trying to drill to fit traditional manifolds....
I have a pair of 416 heads from my old LG4 sitting around, and I just would like to know what all must I do in order to use them with the roller set-up since I know the LG4 used a hydraulic flat tappet?
If this questions been asked before, please point me in the right direction!
Thanks!
Thanks!
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Freshen em up and bolt em on.
Jim85IROC
close
And make sure you have springs that can handle the LT1 roller cam. I suspect that the LT1 cam has a lot more lift than a stock LG4 roller cam, and certainly more lift & ramp rate than an LG4 flat tappet cam.
!!!!Would Z28 springs that can handle .600 lift be too much?
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
Well since "Z28" springs can only stand about .500" of lift if set up with enough seat pressure for aftermarket cams, and that weenie stock LT1 cam only has about .440" - .460" of lift depending on which one it is (there's about 4 or 5; the B-body ones are SUPER weenie, and tend to be the more common), they should be totally fine.
Would springs from my 906 Vortecs work?
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
No.
New, they're weenier than the springs from the 416s are after 20-odd years.
