305 TPI into a 383 Stroker
Old Apr 9, 2012 | 01:18 PM
Russ87ROC's Avatar
Car: 87 Iroc Z, hard top
Axle/Gears: 2.73 or 3.23, not sure...
What’s the best way to go about this? I’m a year out from starting the project but I have so many people saying a lot of different things. I just wanted to see what some of you think.
Here are the stats:
1987 Iroc Z 305 TPI, automatic, 157,000 miles on current motor.
Any insight will be very much appreciated… Thanks!
Old Apr 9, 2012 | 10:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 TPI into a 383 Stroker
What?
Building a 383?
Buying it?
Installing it ???????????
Old Apr 9, 2012 | 10:23 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
You'll either need to buy a 383 pre built or a 350 block and start collecting parts while you get the machine work done...
Old Apr 10, 2012 | 11:08 AM
Russ87ROC's Avatar
That's the options I've heard the most. It looks like either a 383 crate or a 350 with a modified cam and some other work.
On that note...I'm looking for a reasonably priced 383 crate. Any adivce?
Old Apr 10, 2012 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Spend your money once by spending enough to get one put together right.
Orr89RocZ
Apr 25, 2016 08:28 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
