solid motor mount intall problem
Old Apr 24, 2012 | 09:09 PM
ChevyRS-305's Avatar
Ok so im outside right now and i need help asap. I have a set of solid motor mounts that came in a set of 4(2 on block and 2 on k member) i have a stock k member with a 350 and for some reason i can fit one bolt in the one side and the opposite side the hole on theyou k member mount is 1/2 " off to the outside not allowing the bolt to pass through. Their is only one way the mounts with configure to mount up. Idk here im lost. Please help
Old Apr 25, 2012 | 06:50 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: solid motor mount intall problem
I've seen the Morosos have small mis-alignments, like around 1/16", but with a pry bar, they always go together. If yours aren't Moroso, then they're probably cheap copies from overseas, so I'd toss them in the trash where they belong.
Old Apr 25, 2012 | 09:34 AM
Mine are moroso but idk if camaros have different block mounts than other cars? Last night i did realize the make different size mounts for the block so maybe thats it. I have 1 11/16" and i could go eith 2 1/8" mounts.
Old Apr 25, 2012 | 10:38 AM
Twin_Turbo's Avatar
The lower silver plated k member mounts are the same, however there are 2 or 3 different upper parts, teh gold plated ones that go on the engine. If you have the wrong ones it will most certainly not work. I have moroso sets on several cars, they were never a prob but I did verify that the ones on my corvettes are different from the ones on the f bodies (vettes do not use the silver plated k member mount) and the 3rd gen mounts are not the same as the 2nd gens if I remember correctly.
check the moroso site, the numbers are on there
jhawkeye
May 25, 2022 06:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
