Which 350
Old May 9, 2012 | 12:46 AM
  #51
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Which 350
Originally Posted by MGM-RS
Can anyone tell me why in the world the flat tappet cam 330hp 350 cost more than an L31? This just doesn't make sense.
The fancy chrome rocker and timing covers?
Even bigger price difference @ Pace Performance
$1930 http://paceperformance.com/i-6484922...-4-ton-up.html vs $2990 http://paceperformance.com/i-6255511...te-engine.html
For me the $1K difference between the two would have me buying the L31 and using the savings to pay for ta roller cam of my choice and a new intake;
maybe something left over for some bling
NB; pretty engines don't make any more Hp ; people just expect them to
Old May 9, 2012 | 09:53 AM
  #52
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Re: Which 350
The motor is a 99 Vortec and I am not sure if it is a roller or not. There is no gerdal to hold the lifters. Can it be a roller? I have checked the numbers and it is a Vortec. Could the guy I got it from just put in a flat tappit cam in it? I don't have roller rockers that is yet. I am going to buy the ones with a 1.6 ratio. What are the stud 3/8s or 7/16s?
Old May 9, 2012 | 04:45 PM
  #53
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: Which 350
Don't buy anything until you find out what you have, what you want, and what you need. Start researching.
Old May 10, 2012 | 11:40 AM
  #54
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Which 350
If there is no spider/dogbones to hold the lifters then it is not a roller cam and it is NOT a 99 Vortec engine. Is it a 99 Vortec or is it a 330hp Crate engine? The GMPP 330 Crate engine is flat tappet. The 99 Vortec is roller.
Either way, you've got the good heads. If you want to convert it to a roller cam you can do it for between $600 and $1200.
Old May 12, 2012 | 12:45 PM
  #55
gregl316's Avatar
Re: Which 350
Well with the help of everyone here and the internet I found out several things about the motor. It is just a 330 horse Vortec headed (but the numbers are rite for the block too) crate motor bought from probably Summitt. Any how I got a great deal. I have been selling all the carb parts off of it and when it's all done I'll recoup 90% of my money.
I bought a GM Performance smog intake off eBay. I am going to put cop car injectors in. and I know I said I wasn't going to do it but I'm putting smog headers on it and upgrading my exhaust. Since it's on an engine stand Is there anything else I could be doing to make it more of a screamer? Should I up grade the ignition? Should I upgrade the oil pump? I was going to put roller rockers on it would I be wasting my money? What size are the studs? 7/16s or 3/8s.
Knowing what you all know can you recommend a plug? What about oil? The engine has about 6k miles on it so I don't need to break it in. Should I get a high volume water pump? Should I buy a new dist. Mine has 164k on it? I just tuned it up and it is running great so my dist to me seems great. What about the sensors? All the ones the screw into the block. I am going to buy a new knock sensor so the 350 will work.
I am so excited about this swap. Now on to basic engine 101. I am embarrassed to ask but here it goes. Which way does the dist go. All I've worked on in the past 10 years has been an Olds 455 so I have forgot chevys.
Old May 12, 2012 | 12:58 PM
  #56
gregl316's Avatar
Re: Which 350
another quick question. What is the torque sequence and torque for a Vortec intake.
Old May 12, 2012 | 08:47 PM
  #57
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Which 350
you have a pm!!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
