1986 Camaro Restoration and Engine Swap
Old May 3, 2012 | 09:50 PM
samman198's Avatar
Car: 1986 Berlinetta
Need some help with an engine swap. 1986 camaro with a V6, 2.8L TBI, and I am swapping the V6 for a V8, 1991, 5.0L TPI. Need some expertise on matching the 91 engine wire harness with the 1986 vehicle. See attached word doc.
Old May 4, 2012 | 08:24 AM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Re: 1986 Camaro Restoration and Engine Swap
these folks are my neighbors....been helping them out for the last year with this prroject...the thing is ready to run! so if somebody can help us with the repinning of the wire harness that would be great! thanks!
Old May 6, 2012 | 10:37 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
the 6 pin i can explain from experience. the blue and green wires are for the reverse light switch for a manual trans application. the pink and pink/blk stripe are the fused 12 volt wires to the injectors labeled in the fuse panel usually as INJ1 and INJ2 (i think..) tan/wht cant remember right now. the important ones are the injector wires. now one problem i can see arising is the fact that the 91 has VATS. have you had it programmed out of the memcal? i would have to look at a 91 harness that i have sittin around to get a feel for it all again. (i swapped it into an 88 gta once upon a time. then got rid of the car and got the harness back) they may have taken both connectors and put all wires thru one connector.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
