Using a 350 block as a base for a 302
Old May 16, 2012 | 03:21 PM
  #201
mustangdmurder's Avatar
Car: 1982 Z28
Engine: three 350s, all casting #370010
Re: Using a 350 block as a base for a 302
Originally Posted by Apeiron
Put down the magazine and go drive one before you decide it's streetable.
Tell me honestly have you ever driven a 360HP 305?
Old May 16, 2012 | 03:27 PM
  #202
Car: 1982 Z28
Originally Posted by InfernalVortex
And lets talk about making a 305 make 350fwhp.
It will take aftermarket aluminum heads or ported, specific, factory heads. It will take a big roller cam. It iwll take ARP rod bolts and it wouldnt be a bad idea to get H-beam rods to help it hold itself together. Nice aftermarket crank. Cast is okay, but it's gotta be a quality crank to handle 6500+ RPMs. Big cam needs strong valve springs. You'll need a good intake. Kiss that TPI goodbye. You iwll need a Holley 650DP at least, and Performer RPM or a single plane intake. You will need 4.10+ rear end gears, you will need a huge stall converter. You will need the best headers you can fit on it. The cheapest yuo could do it is Hedman long tubes and a dual 2.5 exhaust. And you will HATE every second of trying to drive it on the street. You will be turning 4000 RPM just to get it rolling from a stop sign.
Just not practical at all.
Lets do it with a 350.
You will need at least Vortec heads. You will need a roller camshaft like an xr276. You will need the same awesome exhaust you would have put on the 305. The same carburetor and intake (Performer RPM or better), and you'll need to tune it perfectly. You MIGHT crack out of it around 350-370 fwhp if you're lucky. And it will have much better street manners. But most 350's have a hard time putting out 350 fwhp and staying streetable. The key is to use Vortecs or aftermarket aluminum heads like Brodix IK180s or AFR180's or so on and so forth. Cheap pro comp crap isnt gonna cut it. You will still need a stall, but a less extreme one, and you will probably need 3.42 gears to help get it rolling.
Those 70s 350 heads, cams, intakes, carbs are not good enough. they iwll keep you at 150fwhp. You need to spend some big money on heads. And at the end of the day, you've barely eeked out LS1 levels of power for more than an LS1 costs, with less gas mileage, and the smog police will tear you a new butt hole if you ever go to a place where that matters.
The LS1 weighs 200 lbs less. It makes the same power as the hotted up 350 does with a factory cam. Just an LS1 alone is enough to get a thirdgen into the 12's. If you put a new cam and intake on the LS1 you're 450+hp. You will NEVER get a streetable 350 to 450+ horsepower. It just won't happen. You gotta be building that thing PERFECTLY to get anywhere near 400hp on a streetable 350. It's just not that easy to do. The LS1 can hit that if you sneeze on it wrong. Plus, like I said, it's 200lbs lighter and gets better gas mileage and it will do all that through factory exhaust. Put some long tubes and duals on it and you get even more out of it. Simple bolt on mods with an LS1 will walk well-built mild 383's!
TPI? My Camaro has a carb. I am pretty sure I have seen plenty of 600+HP 383s and exactly mild 383s not built 383s.
Old May 16, 2012 | 03:28 PM
  #203
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, have you ever driven a car with a 360 HP engine of any displacement?
The point is that "streetability" is a subjective quality. Magazines are notorious for promoting "streetable" engines with over-inflated numbers that most people might accept for a weekend cruiser but would rapidly despise for a daily driver. You don't yet have the experience to evaluate the article's content objectively or subjectively.
Less talk, more do. It doesn't matter what you do, even if it's "wrong". Just do something and you'll learn from it.
  #204
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Show me a mild 600hp 383
Old May 16, 2012 | 03:29 PM
  #205
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You have never seen a mild 600 HP engine.
Old May 16, 2012 | 03:30 PM
  #206
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
360 horse for a 305 is the limit of its power where as any baseline power number for an ls engine is close to that to start with and grows with cam, heads, intake, tune, exhaust etc. youll be wasting your money on the 305
  #207
Car: 1982 Z28
Sorry I can see how you misunderstood that. I meant exactly you are comparing it to a mild 383s but there are not so mild 383s that get 600+HP.
Old May 16, 2012 | 03:31 PM
  #208
midias's Avatar
I have but it was a 502
Old May 16, 2012 | 03:32 PM
  #209
Car: 1982 Z28
I'll have to ask my dad if he thinks that would be streetable. When did you drive a 360HP 305?
Old May 16, 2012 | 03:35 PM
  #210
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
When you come back disappointed, dont blame us for not trying to help you out.
Ive never driven one, but been for a ride in one. Super sick car, loved it. He's got a 6.0 LS engine in it now, though. Easier to drive on the street than his 305 was and it makes a little less than 600hp.
  #211
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And they come with an appropriate price tag, and how do you think they perform on the street?
Old May 16, 2012 | 03:36 PM
  #212
midias's Avatar
Really shitty unless you have forced induction.
  #213
five7kid's Avatar
Transmission: 4L80E/4L80E
On Virtual Engine Dyno. At least that's what it said my combo made. More likely it was 300 HP.
Old May 16, 2012 | 03:37 PM
  #214
Car: 1982 Z28
I have no idea on the price tag, but I'll build my own motors no crates for me. I would imagine they kind of jump as they idle.
Old May 16, 2012 | 03:39 PM
  #215
Car: 1982 Z28
So Apeiron drove your car?
Old May 16, 2012 | 03:41 PM
  #216
Car: 1982 Z28
So if you think it was sweet. Then why would you say that it is no good?
Old May 16, 2012 | 03:42 PM
  #217
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're going to pay for parts and machining. The TrickFlow 175s from your favorite 305 article are $1000 a pair in their cheapest configuration.
How many mistakes can you afford to build while you learn? Keep in mind that everyone builds an engine they wish they did differently.
Old May 16, 2012 | 03:47 PM
  #218
Car: 1992 Camaro RS
He is the first guy to tell you that as soon as you touch the bottom end, there's no point in building a 305. He's got a 6.0 LS engine in it now, though. Easier to drive on the street than his 305 was and it makes a little less than 600hp. And his wasnt at 360hp.. that's a bit of an optimistic number.
I would say that it's no good because it wasnt very streetable. it was a pain in the butt to drive around every day. Hes a gearhead and loved it, it was worth it to him. But most people here lack taht kind of patience. We'd rather have the same horsepower and MORE street manners. And the thing is, if you build a 350 or a 383, you can get way more horsepower and still have decent street manners.
Look at this picture:
Do you notice anything unusual about it? Like the giant 2 inch primary long tube headers? The fact that it's not turning its own power steering pump, water pump, smog pump, or alternator? Is that really a realistic extrapolation to saying it's a 360hp 305 in your car? You will put some crappy shorties on it and run it through a single 3 inch exhaust. You will run power steering, alternator, and water pump, etc. That 360hp is closer to 300 rwhp (real world horse power)
I personally wish I had just built a 383 instead of my tiny 350. Building a 350 is a waste of time and money at this point I think. LSx's are the new 383s, and the 383's are the new 350's.
Old May 16, 2012 | 03:48 PM
  #219
Car: 1982 Z28
I wouldn't necessarily buy those. There is a machine shop right by were my dad works and I could see if they could make some custom ones for my 305. Which would still probably be cheaper because they change about $400 for a set of performance 305 heads.
Old May 16, 2012 | 03:56 PM
  #220
Car: 1982 Z28
I didn't notice that when I read the article. So you are right it would produce something closer to 300. My guess would be something inbetween 290HP and 320HP, but I would imagine that the torque wouldn't really be effected would it?
  #221
five7kid's Avatar
No, wise guy.
The point being that what is claimed (by magazines, by engine simulators, etc.) is usually quite different from reality.
There is a lot of real-world experience being ignored here.
Old May 16, 2012 | 04:00 PM
  #222
Car: 1982 Z28
Yeah InfernalVortex did a job of pointing that out with that magazine picture. Before I read that article I was thinking my 305 when I was done with it would produce about 290 to 320HP and about 330 pounds of torque. That article made me think I could get 360HP and 350 pounds of torque but after Vortex pointed that out, I think my original estimates are a lot closer to what it would really be.
Old May 16, 2012 | 04:15 PM
  #223
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
torque id say would be lower. it may hit 1 hp per cubic inch but i dont think it would go past that on a car with all its pulleys etc.
Old May 16, 2012 | 04:18 PM
  #224
Car: 1982 Z28
So more like 290 pounds or toque for a stock LG4 without smog control and A/C?
Old May 16, 2012 | 04:20 PM
  #225
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
id think so, but thats just me. 305's arent torque monsters. youd have more hp than torque if im thinking correctly
Old May 16, 2012 | 04:22 PM
  #226
Car: 1982 Z28
I think you are right about torque number but I think the 305 would have more torque because the small bore and larger stroke, unless you did some serious work to it because it is a lot easier to get more HP than torque.
Old May 16, 2012 | 04:25 PM
  #227
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
either way the numbers wont compare to a 355 with a few goodies, and that wont compare to a 383 and that wont compare to any LS based engine
Old May 16, 2012 | 04:26 PM
  #228
Car: 1982 Z28
Agreed the 305 isn't the best Chevy v8 made, but I like having correct motors. I would even upgrade a 265 if I had a 55 Bel air or Corvette. haha
Old May 16, 2012 | 04:34 PM
  #229
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
why does it matter though. if you want a correct motor build it to stock specs. its no longer a correct motor if you build up its punyness. and when you build it up it becomes less and less streetable whereas a 5.3, 6.0, 383, 454 for that matter are more streetable right out of the box in almost stock from with less into them and pushing way more power than youll get out of a 305. i think your priority needs to be if you want power or individuality because in honesty saying you want a correct motor and saying you want power isnt making sense because your car isnt numbers matching. i guarantee a ton of parts have been replaced in the past so the whole original factor is gone. if you want uniqueness then not many people are going to help you out, thats the sad truth about it.
build a mild 350 or put in a stock 4.8, 5.3, ls1, 6.0 and call it good because then you have a broad spectrum of power increases while keeping streetability and having decent mileage. gen 1 sbc are outdated simple as that. lt1s are cheap and so are lower cubin inch ls motors and would run circles around that 305 or some 350s
Old May 16, 2012 | 04:41 PM
  #230
Car: 1982 Z28
I would argue with first generation small blocks being outdated. They are classics and classics are never outdated, but there is no deny that an LS would run circles around a 305. A 305 will kill anything any kid in my town has. They all have economy cars like Dogde neons, S10s and Grand Ams.
Old May 16, 2012 | 04:42 PM
  #231
Car: 1982 Z28
And they put racing stripe stickers on them and think they are fast.
Old May 16, 2012 | 04:45 PM
  #232
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
so are you trying to street race them to prove a point and be a typical dumb teenager? what says you have to prove anything to them. yes they are in every way outdated even the ignition is outdated because when theres lt1s and ls1's in stock form putting out more power than a built sbc then its made pretty clear at that point
you may always have more power than the kids in there eco cars but yours is also twice as heavy. theres more than just horsepower ratings if you start racing which i dont condone doing on the streets
Old May 16, 2012 | 04:48 PM
  #233
Car: 1982 Z28
Just want to show old school muscle will kill their junk.
Old May 16, 2012 | 04:49 PM
  #234
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
you have a lot to learn then
Old May 16, 2012 | 04:54 PM
  #235
Car: 1982 Z28
Oh I know. I don't know anywhere as much as I would like to. I think think building 305 would be interesting build. I would love to see what I could do with one in my Camaro.
Old May 16, 2012 | 05:04 PM
  #236
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
lots of good info in this thread. build what your budget permits. think about your end goal. do you want something streetable? worried about gas milage? is it gonna be a drag car?
IIRC, the dz302 was made because of class rules in the can am series? not because it was wonderful. they had a 5 liter limit.
i have to admitt the ls engines are the way to go today, but not every budget affords it.
im kinda old school, but my belief is that compression builds power. problem is do you wanna run race gas? if you do a turbo or supercharger, will you keep boost down so you can run pump gas?
instead of a 302,...if i was going that route,..id start off with a 400 block. then youd have a 321CI motor. but as pointed out,...torque is what you should be after. high RPM horse power is only good at,... well,...100 percent throttle. this is a rookie mistake where most people over-cam theyre engine. unless of course your building a race car.
a 305 can be built up, but your better off saving your money.
Old May 16, 2012 | 05:10 PM
  #237
Car: 1982 Z28
Yeah see that is were I am conflicted for now I could either leave the 350 in or buy a LG4 305, but I really like having the correct block and I hopefully will be buying an old truck this summer. It would probably be cheaper to buy a 305 and drop it into my Camaro and put the 350 in the truck. (I am buying a roller. People want too much for a truck with an engine. haha)
Old May 16, 2012 | 05:28 PM
  #238
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
I drove 7 hours one way just to buy my car. I drove 2 hours to get my T56. Are you afraid of driving? Whats one afternoon of driving to get a good deal on a sweetcake engine like an LS1?
70s 350's are the epitome of garbage. 305's should be given away for free. Period. If you want to go through all taht trouble to have some terrible 70s 350 or 305, then by all means, dont let me or anyone else stop you.
But you can get an LS1 for $2500-$4000 easy. You can get a truck 5.3 or 6.0 for $500-$1500. WAY better option than some junky 70s 350 thats worth more as a paperweight than an engine. Dont even consider a block that isn't a roller block.
I wouldn't call a 70's 350 junk(most of the modified cars on this forum are probably 70's 350 blocks), It's a great starting point. We have all had this debate before, the initial cost of an LS swap is not cheap not to mention getting it tuned. I would love to have an LS but I couldn't afford to swap to one right now and there is no place close to have it tuned.
Mark.
Old May 16, 2012 | 05:33 PM
  #239
five7kid's Avatar
Here's some real-world information (all at our 5800' elevation unless otherwise noted):
Stock '86 LG4 (in an '82 Berlinetta), 2.93 gears, open element air cleaner, best 1/4 mile 16.80 @ 80 mph. MPG ~20-22 commuting.
LG4 on steroids: Ported World Products heads (1.94/1.50" valves), ZZ4 intake, Crane H-272-2 flat tappet cam, L69 dual snorkel air cleaner, Hooker 2055 headers, 3" cat-back, 2500 stall converter, shift kit, 3.08 gears. Best 15.80 @ 90 mph. 18-22 mpg commuting. (That's the "360 HP" Desktop Dyno combo.)
350 shortblock under the above: with ZZ4 hydraulic roller cam & 3.23 gears only changes, best 14.1 @ 95 mph. Still the same '86 LG4 carb/distributor/ECM. 18-20 mpg commuting.
LS1/4L60E, shaved 317 heads, LS6 cam & intake, Melling oil pump, Hawks long-tube LS headers, same 3" cat-back, shift kit, 3400 stall, 3.73 gears, stock tune, best 12.88 @ 106 mph. Steady 18 mpg commuting (because I can't keep my foot out of it at stoplights). Last summer I drove it 200 miles to a different track, made 9 passes, drove it 200 miles back home, averaged 21 mpg for the trip (including the nine 1/4 mile passes). Last September, it ran 12.03 @ 112 mph at Brainerd International Raceway (I trailered it up there, because I didn't want to risk breaking something and having no way of getting it back home). I haven't had it dyno'd, but that's about 385 HP to the wheels, better than 450 HP at the crank. Pretty simple combo. I spent $2k for the engine/trans (plus another $325 going to Phoenix to pick it up), and another $4k or so on the "stuff" to put it in and spiff it up a bit (like the converter, shift kit, having the heads shaved, the LS6 stuff, exhaust, etc.). Another $600 if you count the rear end gear stuff (had to buy a new posi along with the gears).
Old May 16, 2012 | 06:02 PM
  #240
Car: 1982 Z28
So what do you think my 350 truck motor would do if I put 64cc heads with 2.02 valves and a new intake on it?
Old May 16, 2012 | 06:04 PM
  #241
midias's Avatar
What a random question with zero information. What casting what intake?
Old May 16, 2012 | 06:05 PM
  #242
Car: 1982 Z28
And does the Berlinetta have smog control and A/C?
Old May 16, 2012 | 06:10 PM
  #243
Car: 1982 Z28
These heads http://www.ebay.com/itm/327-350-CHEVY-ALUMINUM-CYLINDER-HEADS-SBC-2-05-ANGLED-PLUG-200CC-/360440454713?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item53ebecde39These heads with this intake http://www.summitracing.com/parts/EDL-2101/ and the stock Carb off an LG4.
Old May 16, 2012 | 06:33 PM
  #244
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You guys are living in a dream world. You're getting great advice from several guys to not waste your time with a small displacement v8, and you just constantly ignore it for the sake of being "different". Being different is great but you're gonna be slower. Being different does not make more horsepower or save you money.
There's so much ignorance blowing around it's making my stomach turn. "Rev" ability in a smallblock chevy is dependent on camshaft and valve train. Then you build the bottom end to survive the abuse. There are big block turning 8000 RPM's. You have fundamental misunderstanding of how to make power.
The engine is an air pump. The more air that gets shoved in, the more torque you make. To make torque, you pump lots of air. Displacement sets an upper limit for air movement, and the airflow path restricts it from there (there are ways to get to 100% and higher volumetric efficiency but im not going to confuse you with that, it just comes with a well built engine).
Horsepower/speed is derived from torque. But horsepower is torque x RPM. The smallblock chevy is limited by being a 2 valve pushrod engine to being undervalved and limited in RPM capability. You can go higher in RPMs, but it cost a lot of money to make that happen within the Gen I sbc architecture. Beyond this, the smallblock chevy, like any other engine, has a limit on usable power band range, usually 3000-4000 RPMs of useful range.
To make power, you make torque quickly (Read: high RPMs). To make torque you flow more air. To flow more air quickly, you have to tune the whole engine for high RPMs, to tune the whole engine for high RPMs, you sacrifice low end power. It's a spiral-loop of performance requirements that inevitably result in streetability tradeoffs.
What does all this mean in the real world? The more displacement you have, the more torque you will make. The more torque you make, the higher you can shift the power band, the more you can shift that available torque up into the high RPMs, the bigger cam and heads you can use, the more power you can make. But THIS is the key, the more displacement you have, the more you can do all those things, and still have low end torque left over to move the car even outside of the engine's ideal operating range.
The goal is to make as much power as possible and still be able to drive the car. You balance drivability (low end torque/street manners/vacuum, etc, all either the same thing or symptoms of the same adjustments) with high RPM power. A secondary, or even more important goal for some, is to make as much power as possible within a given budget. Both will reach the same end result.
What you have is a mildly complicated system of inter-related factors, and in order to understand it, you need to spend some time figuring it out before you start throwing out nonsensical comments and regurgitating phrases from the 60s hoping it will stick. These old adages may be wrong, or they may be right, but the important thing is taht you understand the roots of them. If they are incorrect, there is a grain of truth or a reason for the misconception - figure it out!
Torque is created by airflow. Displacement sets an upper bound for maximum airflow. To make horsepower (torque x RPM) you can either 1. Increase airflow 2. Increase High RPM efficiency 3. Increase displacement.
Note how these 3 elements are all inter-related. Increasing displacement will increase airflow. Your volumetric efficiency will likely go down if you're using crappy heads, but even with craptastic factory heads, a 400 will pull more air through the same heads than a 265 will.
You can make a 305 fast with factory 416 heads. How? Spin it faster. Put a giant cam in it optimized for a 3000-7000 RPM power band, spin it to 7000 RPMs and the car will be very fast. But it will be unbearable to drive on the street because there's no torque left over in the low range and it will have terrible street manners.
Lets try a different way. We can just flow more air. Buy some AFR cylinder heads. $1500. That will flow more air throughout the power band. And you will get GREAT volumetric efficiency. Most of that 305 cubic inches will be filled with fresh air/fuel mix. If you want to make more power from there, what can you do? Optimize it for high RPM torque, or increase displacement. Or you can leave it alone. But remember, $1500 heads get more return for your investment on larger engines. Increasing the RPM capability of your bottom end gets expensive very quickly. Increasing the displacement of your bottom end starts to make more and more sense.
The logical conclusion to ALL of this is you make the biggest engine you can. The bigger the engine you make, the bigger parts you can put into it that flow more air. The problem is that most parts taht flow more air do so at higher RPMs and flow LESS at lower RPMs. Namely the camshaft, but heads with large ports have the same effect. You lose low RPM port velocity with big ports, ESPECIALLY with smaller displacement engines. Bigger engines allow for lower engine speeds with the same airflow advantages. More cubic inches offset EVERY one of these drawbacks that rear their heads on smaller engines.
Consider that a 305 TPI can spin to higher RPMs effectively than a 350 TPI without that terrible intake holding it back.... but which makes more power? The 350, even though its airflow capabilities tax out the TPI intake much sooner. If you put an intake/heads/cam optimized for high RPM onto a 302, it will work well at high RPMs. If you put that same cam, heads, and intake onto a 400 smallblock, it will make MORE power, at reasonable RPMs. The larger displacement flows more air per stroke, so everything behaves differently, and it brings the RPM range down.
BIG CUBIC INCHES FACILITATE BIG POWER.
Here's another angle. The Gen I sbc, frankly, is a terrible performance platform. It was good in its day, but it's better suited at towing RV's and groceries around. It's been surpassed. The torch has been passed off. the Gen III and Gen IV smallblock (the LSx engines) are much better. Why? The same 3 rules of power still apply. 1. Airflow 2. RPMs 3. displacement. So why is it so much better?
Because its MUCH more efficient with airflow, it's much lighter, and the engine management systems are far more advanced. Factory LS1 heads outflow most aftermarket Gen I heads. a 2002 LS1 head flows nearly 260cfm through the intake port. A vortec head cant hit 230cfm. A $1500 set of 180cc AFR heads for a Gen I block flows 260cfm, the same as a STOCK LS1 head. Thats why you can POUR money into a Gen I smallblock, $1500 for heads, $500+ for fancy roller camshafts and valvetrain, and on a 350, you struggle to hit factory LS1 power numbers.
Sure, you can put a big lumpy roller cam into your AFR headed 350, something like 230/230 duration at .550+ lift. And you can hit maybe 400... maybe 450hp and keep it marginally streetable. That's 50-100hp on an LS1. But remember, the LS1 is using a baby-sized factory cam and a manual 02 Z28 can put down 300 REAR WHEEL HORSEPOWER. 450 fwhp AFR/lumpy roller cam 350 will translate into 380-360 rwhp.
So now realize, when people are spending $1500 on cylinder heads, and $500+ on a roller cam and valve springs and fancy pants lifters for their Gen I sbc's, if they dont build a 383, a factory stock LS1 car is going to hang close with them. Some dentist with a mid life crisis compared to all of our work and money invested into a 350.
To build a NICE 302, 305, or a 327, or even a 350 for power these days is IDIOTIC unless you want a dentist in a bone stock LS1 car, or even an LT1 car to embarass you in every category except noise.
If you're going to put the money into a project to do it right. NICE heads, NICE medium sized roller camshaft, intake matched to everything else, headers, exhaust, etc etc... why on EARTH would you sandbag the potential of all your monetary investment with some puny 302 or 327? The high revving short stroke myth is BS, but with a 302 or 327 or even a 350, revving it is THE ONLY WAY you can be competitive, and that doesn't make for a fun street car. Plus the bottom end parts required to make a 7500 RPM 302<->350 are WAY more expensive than a stroker kit to make a medium RPM 383.
Remember, every single performance part you buy will have a tradeoff. You will lose low end torque, or gas mileage, low RPM port velocity, durability, vacuum, etc, and in exchange you get more horsepower. Do you know what the tradeoff is for discplacement? There isn't one. It's the ONE change you can make, that wont result in a loss of streetability in exchange for horsepower. Well, displacement and exhaust.
Try to understand the relationship between torque, RPMs, and horsepower. And then try to understand the relationship between a given performance part, displacement, and torque. And by torque in the second sentence, I mean where in the RPM range is torque added and where is it taken away. You will hopefully see the patterns.
This should be made a sticky and essential reading for any newbie planning a engine swap
Old May 16, 2012 | 07:12 PM
  #245
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The point is that &quot;streetability&quot; is a subjective quality. Magazines are notorious for promoting &quot;streetable&quot; engines with over-inflated numbers that most people might accept for a weekend cruiser but would rapidly despise for a daily driver. You don't yet have the experience to evaluate the article's content objectively or subjectively.
Less talk, more do. It doesn't matter what you do, even if it's &quot;wrong&quot;. Just do something and you'll learn from it.
Amen!
Old May 16, 2012 | 07:15 PM
  #246
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No, wise guy.
And Amen
Old May 16, 2012 | 07:20 PM
  #247
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And..no, wait, this isn't perfectly true, nor is it fact. I'll happily and readily put a $1500 Vortec 350 build up against a $1500 5.3L LM7 swap, if you can do it that cheap. I'll likewise put up an AFR-headed 383, built by me, against even a stock LS3. Only the first part is correct, about 305 vs 350, even factoring in the cost to get the 350. Even figuring one axle gear taller for the 350, to equalize MPG. Which, BTW, extends the life expectancy of the 350. Though we won't factor that, since you'll get bored with it long before it wears out.
Old May 16, 2012 | 07:32 PM
  #248
Car: 1992 Camaro RS
Mark.
I dont disagree with you, I just see it a little differently.
If you're gonna use an outdated gen I smallblock, the least you can do is go with a roller cam for reasons of more power, more efficiency, and better reliability. The advantages are all over the place for rller camshafts. Going to a roller cam with a 70s block costs about twice as much as doing it on an 87+ roller block where you can use factory lifters. Furthermore, with a 70s block you're limited to a flat tappet cam, or spending WAY too much on converting to a roller, but beyond that, there is absolutely NOTHING in that block that is worth re-using. If you're building a mild 350, you can reuse the crankshaft and MAYBE the rods. Still need new rod bolts, and that plus the refurbishing costs of the old rods costs almost as much as new entry level rods with ARP bolts. So it doesnt make a whole lot of sense to reuse the rods.
So all you're buying is a block and a crank, and a decent aftermarket cast crank is better than a factory crank and it's only a couple hundred bucks, pocket change compared to the rest of the engine build expenses. A stroker crank is only a few bucks more than that. Decent cast stroker crank is $250 or so if i remember right, and those are going to be way stronger than any factory 400 crank.
And as far as the cost of an LS swap. It's basically new motor mounts, new serpentine assembly, and a new transmission and trans mounts. I find the transmission is the complication, but you can get a truck 5.3 motor for $250-$1000 everything included. A 6.0 is pennies above that. The truck 5.3s even have aluminum heads. They make 300fwhp stock. That's about as much as my honestly pretty well-built Vortec heads 355 is making with all the mods I have done to it. And the truck is my daily driver. Beyond that you can even bore a 5.3 out to use LS1 pistons and make an iron 5.7 if you so desire, but even then the huge improvements in the Gen III+ architecture mean even gonig down in displacement to a 5.3 is well worth the effort because with just a nice roller cam, an intake swap, and maybe a head swap (all to things you can reuse in an LS1 or 6.0 engine) you will make enough power to embarass hot 350s and 383's.
I like the idea of going to a 5.3 or even a 4.8 because they're still faster than anything stock in our cars, they're lighter, theyre cheap, and they're a good way to get the conversion done for cheap and you can build an LS1 to drop straight in later, just bolt it up. Plus the 5.3 and 4.8's use teh same block, so you can go to an LS1 crank and pistons and bore them out to 5.7 liters.
Old May 16, 2012 | 09:16 PM
  #249
Car: 1982 Z28
Vortex you are obviously no car enthusiast. Saying the first generation small blocks are junk is . The LS motors are based off of the first generation small block. Even if they aren't as nearly as good as the LS motor (which I completely disagree with by the way), the LS motors are based off of them and you should pay respect where its do.
Old May 16, 2012 | 09:49 PM
  #250
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
I know a LS motor is the way to go, And I probably will do that in the future. I'm not going to sit here and say my 350 is hot but it has embarrassed a few LS powered cars. I also have a couple friends that have 10 sec naturally aspirated LS powered cars, very fast street cars(not race cars) that can drive to the strip run a 6... second 8th mile time and get 24mpg on the way home, So I do agree that the LS motor is a better motor but I had so many parts for the gen 1 already that it didn't make sense to do that at the time. It's all good, not really trying to get in a pissing match on the Internet.
Mark.
