Using a 350 block as a base for a 302
Old May 17, 2012 | 07:58 PM
  #301
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Using a 350 block as a base for a 302
Originally Posted by mustangdmurder
I only changed my mind once
302
305
350
377
I would say that is 4 versions ?
In any case ,
this thread is a complete waste of bandwidth because you have had the best info from some of the most knowledgeable minds online
( there is reason many non 3rd Gen owners come to this site for help )
and you still have your original
" i wanna b different " mindset
Stop the BS and just go and do what you want.
As has been noted ; is your car / your $$$ / your choice
Old May 17, 2012 | 08:04 PM
  #302
mustangdmurder's Avatar
Car: 1982 Z28
Engine: three 350s, all casting #370010
The engine that is supposed to be being discussed in this thread is my 350 block. Which I was thinking about building into a 302, but decided it would be better to build into a 377. I have a 350 that is staying a 350 and I planned before this thread that I was going to put a 305 in my Camaro.
Old May 17, 2012 | 08:48 PM
  #303
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Why are you afraid to bore it out? You do realize boring isn't really a choice, so much as it is a repair, right? The bores oval out over years of use. You bore them out to get them perfectly round again which helps ensure proper ring seal. You bore the block as much as is necessary and if you go to a machine shop that's one of the main operations they do. If it has to go .040 or .060 over then it's not a bad idea to find a different block. If it has to go .030 or less that's great news.
Old May 17, 2012 | 08:56 PM
  #304
Car: 1982 Z28
I had the machine shop measure the bore after that cleaned the block and the bore is 4.0001-4.0002 does it even really need to be bored?
Old May 17, 2012 | 09:06 PM
  #305
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
did they check if it was ovaled?
Old May 17, 2012 | 09:17 PM
  #306
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
nah forget all that build a 396ci out of that 350!
Old May 18, 2012 | 06:01 AM
  #307
Car: 1982 Z28
I would think so.
Old May 23, 2012 | 10:25 PM
  #308
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
383 stroker difficult to build? Thats hilarious, in fact the Small Block Chevy is quite possibly one of the easiest engines to build, or any pushrod engine for that matter. All it takes is your sweet time and checking those clearances.
Old May 23, 2012 | 11:15 PM
  #309
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
so you came on here to be an ***? i have checked clearances and somehow **** keeps changing. not many people know that theres grinding involved on rods or the block or both or one or the other. so if you have a negative comment keep it to yourself i was trying to spare him from jumping the gun on anything and having as difficult of a time as i am
Old May 23, 2012 | 11:29 PM
  #310
Car: 85 camaro z28
Engine: 355
Transmission: t-5
My comment was to encourage him not to be scared from one minor incident, aka yourself.
Check your oil pressure? Are you just breaking in the engine? Fresh built engines are usually gonna have metal shavings in the oil pan as parts break in, which is why an oil change is recommended at 1xxx miles.
Old May 24, 2012 | 08:54 AM
  #311
Car: 1982 Z28
I am pretty sure tylercamaro is right. When I researched about making a 383 it said that you have to grind the rods and block.
Old May 24, 2012 | 09:38 AM
  #312
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Any reputable machine shop will take care of it
Old May 24, 2012 | 09:51 AM
  #313
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That's hardly a lot of work. At most, it means that you have to pre-install the rotating assembly one or 2 times to mark the spots to grind and then re-check after you grind it.
Old May 24, 2012 | 09:53 AM
  #314
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Originally Posted by Jim85IROC
To avoid buying $9 race gas.
Ever hear of E85 ? you don't need $9 race gas if you plan you build accordingly.
Also keep in mind the original 302 Chevy's were high-RPM motors built for ASSC road course competition.. The original 302 Z28s were built in small quantities to meet ASSC rules for their "stock" car class which at the time was dominated by Mustangs... and this is how the Pony car wars began.
They were not mass-produced for a reason, and will not fare well on the street and kinda embarrasing when a low RPM torquey "steet motor" beats your "race motor" . The open highway or a track is another matter and I won't condone street racing, that is your business.
Old May 24, 2012 | 11:28 AM
  #315
92RS4US's Avatar
Axle/Gears: 2.73's
there is some "clearancing" involved not but every block or rod needs that. Using a small base circle cam helps, using and H beam rod or using 400 bolts in your 5.7 rods, and you may have to touch the block, you may not. Sometimes you have to clearance the area in the front of the block for a double roller timing chain, sometimes not.
Point is it's not all that bad...the machine shop can do it if you have them assemble the engine.
With respect to tyler sounds like he had the worst case scenario, I had to kiss the rod bolt heads on one rod in my 383 but thats it.
Old May 24, 2012 | 03:01 PM
  #316
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Usually you will need some grinding done on the block, but with a small base circle can you should be ok with the rods
Old May 24, 2012 | 03:49 PM
  #317
Car: 1982 Z28
How much does grinding rods and a block cost though?
Old May 24, 2012 | 04:42 PM
  #318
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're the one building the engine there's no reason why you can't do it yourself... so nothing.
Old May 24, 2012 | 05:04 PM
  #319
Car: 1982 Z28
That is true.
Old May 24, 2012 | 05:50 PM
  #320
Car: 85 camaro z28
Engine: 355
Transmission: t-5
That is true.
No Fear. build that ****.
Old May 24, 2012 | 05:56 PM
  #321
92RS4US's Avatar
Axle/Gears: 2.73's
very little grinding involved. For the rod bolts you just touch the inner bolt that comes in contact with the cam, just enough so it clears, some say .050" minimum clearance. Same clearance spec for the pan rail to rod bolt area. Most 350 blocks have the area where the outer rod bolt passes the pan rail already clearanced for it.
Old May 24, 2012 | 10:58 PM
  #322
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Not more than $120 at a machine shop, probably less unless a lot of clearancing needs to be done
Old May 25, 2012 | 08:59 AM
  #323
Car: 1982 Z28
Yeah I am just trying to think if I have the tools to grind a block
Old May 25, 2012 | 11:59 AM
  #324
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Carbide burr in a cheap die grinder. Or a Dremel-type rotary tool if you've got time on your hands.
Old May 25, 2012 | 01:58 PM
  #325
Car: 1982 Z28
I got all sorts of time coming up here. haha I got a dremel just wasn't sure if that would cut it.
Old May 26, 2012 | 04:20 AM
  #326
poloaa008's Avatar
Learn how to make a 265, 283, 305, 307, 327, 350, 383, 400, or 427 and you'll know how to make a 302.
Old May 26, 2012 | 08:41 AM
  #327
Car: 1982 Z28
Yeah all of the small blocks are essentially the same.
Old Jan 27, 2013 | 12:19 AM
  #328
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
I know how to build a small block if I have the parts but I was wondering what parts I needed.
The only parts spacific to the 302 are the piston and crank everything els can be salvaged from the 350 the heads are probable 76cc as apposed to the 64ccdon't forget they ran alot more compression back then than we can now so that helped the small displacment eng tolerate the thumper cam better; but cam science has come lightyears beyond what was even dreamed back then not to forget heads have evolved also even the much respected rectangular port bbc on the good ports intake flow was only about 266 at.500 oem bbc heads have good & not so good intakes 4 of the intake ports open up into the middle of the bore the others hit the cylinder wallthe intakes port passage are also different length Warning going off on a tangentdoes anyone else remember the early canam cars and series this was bigballs hairychested racing thewhole rule book number less than 20 pages this was run what ya brung take no prisoners racing imagine cars that wieghted2500 lbs or less with 6 to 7 hundered HP CHEVY BB RULED ESPECIALLY AFTER I THINK IT WAS REYNOLDS BEGAN CAST BBC IN AL THEY POKED STROKED THOSE BAD BOYS OUT 494 CID THEY HAD NODULAR IRON LINERS PRIMATIVE AERO BACK THEN EVERYONE COULD GET ONE OF THE UNUBTAINABLE BLOCKS WAS HAPPY EXCEPT FOR FORD &PORSCHE FORD TRIED TO COUNTER W THIER OWN ALUM BB BUT 385 LIMA SERIES 429 & 460 HAS A CRAP OILING SYSTEMCAN YOU SAY 100 PLUS PSI TO KEEP EVEYTHING LUBEDPORSCHE CAM BACK WITH THE LEGENDARY917 TURBO POWER HAD ARRIVED 30PSI OR 2BAR AND NOW YOU NEED 1000HP TO RUN WITH THE BIG DOGS PARNELL JONES WROT ABOUT HIS EXPERENCE TEST DRIVING A 917HE SAID IT HAD ALL FINESS OF A SLEDG HAMMER TO THE BACK OF YOUR HEAD STOMP THE GO PEDAL AND NOTHING NOTHING WAIT FOR IT AND GO FROM LIKE 275HORSE OR 300 TO 1000 IN THE SPACE OF 2 OR 3 SECOUNDS OMGTHE THING WAS A DEATH TRAP NOT ENOUGH TIRE ALMOST NO BRAKES NO WAY TO REGULATE HOW HARD THE TURBO HIT NO ELECTRONICS OR EVEN WASTGATES AT FIRST THEY HADN'T BEEN INVENTED YET. THE ONLY OTH ER RACING SERIES USING TURBOS WAS INDY ON THERE BIG THUMPER OFFY FOURS THEY USED A POPOFF VALVE TO LIMIT BOOST BUT NOT REGULATE ITONCE YOUR OUT ON THE TRACK AND ON BOOST STAYED ON TILL YOU HAD TO PIT NO SHIFTING OR ON AND OFF THE THROTTLE ENGINE SPEED DIN'T VARY MUCH BETWEEN STRAIGHT AND BANKED TURNS SORRY JUST REALIZED CAP LOCK HAS BEEN ON THRUOUT THIS WHOLE LONG ERELAVTANT RANT THAT NONE CARES TO READ ANYWAY.
Old May 30, 2015 | 07:14 AM
  #329
reichs67's Avatar
Car: 69 L89
Engine: 396 L89
Transmission: M22
Axle/Gears: 12B 373
U need 1178 crank
Old Sep 12, 2021 | 08:08 PM
  #330
experienced's Avatar
Originally Posted by Vega
Maybe i should explain this a little further. If the motor is out of the car, yes a 350 is the way to go. No point in dropping in a 305 when its just a de-bored 350 and they both rev the same. A 302 however can be built to rev higher so there may be a reason to drop that in instead of a 350. But if you have a 305 in your car already, especially if its a roller-cam motor, honestly a top-end swap will get you very very close to a full 350 build and swap and will be much cheaper and much easier since the shortblock will stay in the car, plus at that point if you ever do decide to swap to a 350 the whole new top-end will swap right over just as easily. However. as said before, if the block is out already, yeah i agree a 350 or 383 would be the most cost-effective route. Its all about being cost-effective
No amount of anything will Ever get a 305 output anywhere near what a 350 will do. As for the original question, the 302 was created by gm with a 350 block and a 283 crank. The leftover parts created the 307, another boat anchor. A good running 283 will trounce a 305 or 307 in power.
Old Sep 12, 2021 | 10:26 PM
  #331
vorteciroc's Avatar
Top Answer: 1
Actually No.
The 302 SBC was assembled with a 327 Cylinder-Block due to its 2.300" size Main-Journal dimension... Not a 350 Cylinder-Block.
The 283 SBC and the Early-327 SBC both use a 2.300" size Main-Journal dimension.
Where the 350 SBC uses a 2.45" size Main-Journal dimension.
For a 350 SBC to use an actual 283 SBC Crankshaft, Main-Journal Spacers/ Bearing-Inserts would need to be used to make up the difference in size.
This is far from ideal.
Today, with the high availability and affordability of custom SBC Crankshafts...
A Crankshaft for a 350 SBC Cylinder-Block can be ordered in the same Stroke as the original 283 SBC used (or many other Stroke dimensions for that matter) and not require Main-Journal Spacers/ Bearing-Inserts.
Also, in case you were not familiar...
The 400 SBC Cylinder-Block uses a 4.65" size Main-Journal dimension.
O... and please try not to Post on Threads that have not had any activity for several years.
Thanks!
Old Sep 15, 2021 | 08:46 PM
  #332
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Actually No.
Thanks!
350s had a small journal crank the first year they existed. Later 302s were also large journal.
10secondhopeful
Oct 30, 2008 09:21 PM
Jammen Firebird
Aug 23, 2007 12:25 AM
BOTTLEDZ28
Aug 28, 2003 07:20 PM
90RS305
Aug 13, 2003 03:53 AM
