1985 305 TPI to 1988 GTA 350 TPI swap questions
Old May 24, 2012 | 12:04 PM
Blue1990camaro's Avatar
hey yall, i have a 1985 IROC Z28, 305 tpi, i sold it last year, kid blew it up, bought it back, ANYWAY its a 305 TPI, i my friend has a 1988 350 TPI from a GTA
heres my questionm its tpi so it should be plug and play correct? i noticed it a serp belt not v belt like mine and the alternator is on driver side, mines on passenger side... will everything plug and play or will i need to modify the wiring harness for the 350? all the tpi stuff should be the same right?
id be gettin the built motor+headers+full exhaust+aluminum drive shaft+ sway bar.
Old May 24, 2012 | 05:54 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: 1985 305 TPI to 1988 GTA 350 TPI swap questions
Maybe a prom upgrade for the 350, other than that, i would think its just about plug and play from there.
Old May 24, 2012 | 06:13 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
you need to change out the knock sensor the injector the prom and some case the ecm and the esc module you also can go to tpi part .com and go to the tech page and it has more info on this swap. I want to do the same thing in a few year. hope this help.
Old May 26, 2012 | 01:52 PM
i already have an ecm from a 1988 350 tpi iroc
why would i need injectors? its a complete 350 tpi, complete oil pan to throttle body?????? i was more concered as far as wiring and bolting everything
Old May 26, 2012 | 11:32 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
So long as you have EVERYTHING that belongs on that 350 (sensors, injectors) then it should be plug and play from there. If you the ecm for that engine, then you really are all set to go
Old May 27, 2012 | 08:09 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
sorry man i did not read right if you have everything with the 350 tpi motor you will be fine
Old May 28, 2012 | 02:04 PM
yes i have the COMPLETE 350, it was pulled directly from a 88? pontiac GTA, its 100% complete, plug wires wernt even removed when it was pulled, headers and all are still on it,
now what i do not have is the wiring harness from the GTA, i have a ecm from a 88 iroc z, and my car is a factory 305 TPI car
lol
Old May 28, 2012 | 07:30 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
If you are looking to convert your car from a 305 TPI to a 350 TPI setup, then you should find the information below rather useful. These are all the needed changes to do the conversion.
First of all, the TPI intakes (manifold, plenum, fuel rails, throttle body, runners) were exactly the same between 305 and 350 engines of the same year. There were no differences in these parts whatsoever between one engine size and the other during any year (there were however differences between the intake manifold and fuel rails between the Camaros and Corvettes). For example, a 1987 intake was the same for both a 305 and 350. Please note that this does not mean all intakes are the same throughout the years, there are differences between a 1987 intake and a 1992 intake for example.
All your belt driven accessories, brackets, exhaust, etc... will transer over from the 305 to the 350 without any problems. Once you install the TPI intake on the larger engine, you will need to note the following items that need to be changed. These are the only things you will need to change or worry about to properly convert to a 350:
Injectors
The size of the injectors was a very important difference between 305 and 350 applications. ALL 305 TPI engines came from the factory with 19 lb injectors. ALL 350 TPI engines came from the factory with 22 lb injectors. The Corvettes did not have injectors any larger than the Camaro, as I have people often asking. If you want to use 19 lb injectors on a 350, or 22 lb injectors on a 305, you can, but you MUST have the injector size in the PROM changed. Otherwise, you will run into fueling problems.
Knock Sensor
The knock sensor physically looks the same between the 305 and 350 version, but they do are not the same. This is very important, and should not be overlooked. The knock sensor is responsible for detecting detonation. Detonation produces a specific frequency that travels through the engine block. This frequency is different depending on engine size. In addition, it is important to note that the 350 knock sensors were different between the 85-89 TPI setups and the 90-92 TPI setups. You must use the correct one for your application. The 305 knock sensors were also different between 85-89 and 90-92.
ESC Module
The 85-89 TPI setups used an external ESC module which was mounted by the firewall. This module was different between 305 and 350 engines. Changing this is as simple as disconnecting the 305 module, and plugging in a 350 module. The 90-92 TPI setups did not have an external ESC module. Instead, the ESC circuitry is contained inside the PROM. For this and several other reasons, it is important that you use the correct prom for the engine size you are using.
ECM
Although there were several different ECMs used depending on what year TPI setup you have, the same ECM was used for 305 and 350 engines for a given year. The difference between the engines was the prom. In other words, the 86-89 350 TPI engines used the 1227165 ECM, and so did the 86-89 305 TPI engines. The 90-92 350 TPI F-Body engines (Camaro and Firebird) used the 1227730 ECM, and so did the 90-92 305 TPI engines. The 1985 305 TPI engines used 1226870 ECM, which is the same as the 1985 350 TPI ECM (350 was only available on the Corvette in 1985).
The Corvette used the 1227727 ECM on the 90-91 350 TPI engines. Although the Corvette was never available with a 305, the 1227727 ECM can be used on a 305 if desired.
PROM
This is probably the most important change that needs to be made. Regardless of what ECM you are using, the 305 prom is setup very differently from a 350 prom. Which prom you need will depend on what ECM you use, transmission type, engine size, and a few other details. Contact us if you need help finding the correct PROM for your application.
If you have a 90-92 ECM, and you are having your PROM reprogrammed, you must start with a PROM that was originally for a 350. The 90-92 PROMs have the ESC circuitry onboard, and that cannot be changed.
The 85-89 PROMs can be changed from one engine size to another without worrying about ESC within the PROM, since the module is external on those years. hope this will help you out with your swap
Search
Old May 29, 2012 | 01:48 PM
ok so from what im reading i have literaly everything i need except the ESC? module.... hmm now where to find one...
Old May 29, 2012 | 07:17 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
i think you are ready to swap now. tell when you get done i want to see the finish car.
Old May 31, 2012 | 11:55 AM
yea im thinking i dont need the ESC module tho bc its built into the 88s ecm, anyways i cant wait to get my IROC Z back on the road, get er done soon, ill keep yall posted and start taking pics as i get working on her
Old Feb 19, 2021 | 06:47 AM
Schmidi's Avatar
Injectors
Knock Sensor
ESC Module
ECM
PROM
Search
I've just read your post, thanks for all the helpful informations. There are still some questions about my issue:
I'm planing to swap my 305 TPI in my 88 Camaro to a 350 TPI out of a 85 Corvette. Mine has 150'000mls, the one from the corvette has 38'000mls. 15 Years ago i swap the TBI to a TPI and it worked fine since there, using the 12267165 ecm with reprogrammed prom deleting the vats and the 9th injector. This morning i could have a look in the 350.
What i noticed:
- different locations of the accessories, but shoud be changeable i.m.o.
- MAP TPI instead of mine MAF TPI, should also be changeable i.m.o.
- different headers, are they changeble to mine?
Am i right with these opinions?
Do i have to change the ecm anyway or only the prom, or is there a chance that it works on the 350 when using all the sensors from the 350?
Thanks in advance for your support
Sincerely
Stefan
80s Poncho
Feb 13, 2011 07:08 PM
thirdgen4me
Nov 17, 2009 05:35 PM
Z2EIGHT
Jan 10, 2007 11:59 PM
305iroc
Jan 22, 2003 09:17 PM
