Vortec Cam advice
Old May 29, 2012 | 07:54 PM
MartinD's Avatar
Vortec Cam advice
Building a 350 vortec engine and will be converting it to TBI. Looking for a few roller cam choices where i DONT have to have the heads machined and that will work with the computer. Any ideas would be great and thanks.
Old May 29, 2012 | 08:36 PM
KurtAKX's Avatar
Car: Pontiac
Axle/Gears: 3.08 / Drums
Re: Vortec Cam advice
I'm in the same boat and I'm thinking LT1 cam from a Firebird/Camaro/Corvette
Old May 30, 2012 | 02:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.fullsizechevy.com/forum/g...ec-sheets.html
http://www.chevelles.com/forums/showthread.php?t=157785
Old May 30, 2012 | 03:57 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
http://67-72chevytrucks.com/vboard/s...d.php?t=255659
Bigger on the exh side to help with the puny ports and within lift specs for stock springs. The LSA is wide for EGR "effect" and is negligible with such weak sauce lift/duration. Will probably idle at 20" which will greatly please your ecm. Torque-o-rama.
Old May 30, 2012 | 05:42 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
how about a lt4 hot cam an alec valve springs ?
Old May 30, 2012 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you happen to see the budget 350 sticky thread in the top section of the TBI forum?
84z96L31vortec
Aug 20, 2017 12:16 AM
z28addict8490
Sep 5, 2015 03:56 PM
lt1z350
Aug 28, 2015 05:57 AM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
