Stay TBI or no? if no, go TPI or Carb?
Old Jul 19, 2012 | 09:46 PM
V8Broski's Avatar
Car: 1991 Camaro RS
what sshould i do? my dads friend is giving me a free 305 engine and trans with 86,000 miles. before i put it in, im going to be doing work to it. should i leave it TBI? or convert? if i convert should i go TPI or Carb?
Old Jul 19, 2012 | 10:28 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Stay TBI or no? if no, go TPI or Carb?
That's all up to you. I like all three for their own reasons. Each system has it's advantages and disadvantages. What are your plans for the car? I'm guessing since you're getting a 305 the you're just planning on making it a driver. In which case why change it then? Nothing wrong with TBI.
Old Jul 19, 2012 | 11:09 PM
V8Broski's Avatar
Car: 1991 Camaro RS
well i figured leave it TBI no big deal,then i figured figured Carbing it would be cool but wouldn't make a difference and then i tought TPI could make more power. it's being completely redone so not exactly a driver and the reason for a 305 is that my new 305 was free with a trans and i'm 17 a 305 is plenty of power for now, my dad owns a shop and my familys had a large history with cars. i'll be hot roding a 350 on the side. i just want my 305 to be somewhat quicker then the average car, if i switched to Carb or TPI i'd probably be using Edelbrock stuff because i get it factory new for cheap because of my dads shop. i'd really like to just make my 305 cool for now.
Old Jul 20, 2012 | 02:49 PM
Since you're thinking about changing engines in the future, personally I'd stick with the TBI for now. If you feel the performance isn't enough right away, go through the TBI board for upgrade suggestions. There are a lot of things you can do to make a TBI move. As time goes on you just may want to switch to a LSX or LTX in which case money you spend on induction now will be a waste.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
