1984 camero z28 with an L82 engine
Old Jul 31, 2012 | 08:11 PM
icecubescoke's Avatar
Hi I'm looking at buying a 1984 camero z28 project car from my friends dad that got sick and passed away I've been googleing and cant find any info on anything similar it has a L82 corvette engine and I want to know is it possible to have that motor work in this car and if so what else would i have to change out. Im also swapping out the 5 speed for an automatic is there a guide on how to do so if you guys have anything it would help thanks
Old Jul 31, 2012 | 08:22 PM
Re: 1984 camero z28 with an L82 engine
There's nothing special or different about the L82, from any other small block Chevy. Bolts right in.
Old Jul 31, 2012 | 08:39 PM
o okay its already bolted in then thanks just need to hook up the transmission
Old Aug 1, 2012 | 08:00 AM
Yup... and don't forget, they all bolt to the engine the same, but bolting to the rest of the car is a bit more critical.
The only transmissions that will fit the car without modification are the T-5 and the 700-R4. And, those have to be the ones specifically for 82-92 F bodies. Can't use a T-5 from a Mustang or a S truck for example; can't use a 700 from a truck or Caprice (although if you have the one out of the F car, you can take its F specific parts and move them to the other). Anything else,,,,, ..... if you have to ask if the L82 will fit, will be a pretty tall order. I'd suggest putting the OE one back in at first and getting the car going, then tackling a swap later, as you acquire more knowledge.
And BTW, the name of your car doesn't have an "e" in it. It's always a good idea when on a car forum, to match the spelling to what's stuck to the side of the car.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
